94 gt 5 speed cruise control issues
Old November 25th, 2010, 01:14 AM   #1
matholland is on a distinguished road
I have noticed, that the cruise control usually works, whenever you are cruising 60mph+...not always though. When it does work, its constantly pushing the gas, and letting off, and wants to keep accelerating...you got to hold the coast button, as soon as you let off it keeps climbing. It worked 1 time right since i got it...it actually kept speed....
What would cause this? I thought that it might be the switch on the gas pedal or something?
Old November 29th, 2010, 03:49 PM   #2
does anyone have a picture of where the cruise control vacuum line is?
Old November 29th, 2010, 05:36 PM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
It comes off the vacuum manifold in the rear driver's side of the engine bay and goes under the fender to the cruise control module.
Old December 27th, 2010, 03:48 PM   #4
Alright, so I figured out the problem on my cruise....On the clutch pedal, there is a switch I guess. My clutch has a little play in it, and the way it sits it keeps the switch pressed in unless you take your foot after you get done changing gears and pull out on the clutch lever...that allows me to use my cruise. However, if you hit a very big bump, it will shut it off, and you got to pull out on the clutch again...the guy that i bought it from said it has a stage 1 clutch in it, and he had to take out something, and adjust it manually instead of pulling out on the clutch or something? not sure, but is there an adjustment where I can make the clutch pull out a little farther?
Threads Similar to: 94 gt 5 speed cruise control issues
speed control or cruise? 92stangdaytona 2.3 Mustangs 3 February 14th, 2010 06:53 PM
Cruise Control? ncsubowen V6 Mustangs 8 May 17th, 2009 11:34 PM
Cruise Control zinc02GT 99-04 1 December 31st, 2008 08:20 AM
Cruise Control riddlee josh V6 Mustangs 8 December 28th, 2007 04:18 PM
help: cruise control orlyr21 General Tech 1 June 12th, 2007 12:42 PM
