Trying to hit my goal of 300hp...suggestions? - Page 2
Old January 10th, 2008, 08:10 AM   #21
stang94 is on a distinguished road
Originally Posted by Bullitt95 View Post
Stock is ~190-195rwhp on a 5-speed 5.0 GT.
With basic bolt-ons (CAI, MAF, TB, headers, midpipe, catbacks, pulleys) you'll have ~230-235rwhp.
You won't get beyond 235rwhp with the stock heads/cam/intake so to reach 300rwhp, you'll need to change at least 2 out of the 3 (heads & intake). You'll also need other supporting mods like a higher-flow fuel pump, bigger injectors, and a tune.
What he said... keep in mind you will need some suspension work also.
Personal Note:
I got for sale: All Parts are NEW.
New BBK 75 TB MM For sale.
Holley 24lbs Injector
BBK Full Lenght SubFrame Connector w/seat support
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old January 10th, 2008, 10:49 AM   #22
95StangMX's Avatar
95 Mustang GT
with light mods like that you should not need to change the fuel pump or the injectors 19's will be fine for mild heads and intake....
Old January 10th, 2008, 11:58 AM   #23
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
when you get your mods...the tune is the key to the power gains...
Old January 10th, 2008, 01:44 PM   #24
95StangMX's Avatar
95 Mustang GT
Personal Note:
he said goal is to make 300 HP he didnt say anything about his goal 1/4 times or traction...how does suspension work help him to acheive 300HP? LOL...just messing witih you bro
+1 but its not necessary with just minor mods wait and tune it when you feel like you have done most of your major mods tuning takes every little detail into consideration
Old January 10th, 2008, 02:41 PM   #25
He'll need some better control of that car with 300hp lol. I'm sure he's not going to keep it to say I have 300 HP and not use it..
Old January 10th, 2008, 02:54 PM   #26
MikeD05GT's Avatar
2005 Mustang GT
yea only tune when you get major mods...like full exhaust...intake...heads and cams...s/c obviously
Old January 11th, 2008, 04:28 AM   #27
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
With basic bolt-ons and stock HCI, that's correct. If you do ported E7s/ported factory intake (as I did), the 19lb injectors are still OK but the stock fuel pump will be close to the limit, so it's better to upgrade it before doing HCI so the engine doesn't run lean and detonate under WOT at higher rpm.
Larger injectors and a chip tune aren't necessary until you get into HCI mods, forced induction, or a stroker build.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old January 12th, 2008, 02:57 PM   #28
95FiveOh is on a distinguished road
Easiest way to get a sure 300rwhp is by putting together your own h/c/i kit. The most proven one would be a set of AFR 165 heads, a custom cam from Ed Curtis at FTI (Flowtech Induction) and a decent intake such as Edelbrock Performer, Trick Flow Street Heat, ported Cobra, Holley, etc. Combine this with all the bolt-ons and supporting mods such as injectors, mass-air, and a good tune and you can easily see 300+ rwhp. Some have even seen 315-320rwhp on stock shortblocks with great drivability.
Old January 12th, 2008, 06:08 PM   #29
MikeD05GT's Avatar
2005 Mustang GT
^^ sounds like a plan
Old January 14th, 2008, 02:59 PM   #30
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
Trickflow top end kit alone should get ya there. But its $2500 just for the parts. Also go with a Centerforce Dual Friction Clutch, great pedal feel and awesome hold! Have fun building just like I am!.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Old January 16th, 2008, 11:36 AM   #31
Bullitt95's Avatar
13.546 @ 105.32
...and it doesn't end there. With H/C/I, you'll also need the following supporting mods:
Larger injectors ~$350
Higher flow fuel pump ~$150
Tweecer RT self-tuner ~$500
Higher stall torque converter ~$500
So the true cost of doing the H/C/I conversion is going to be ~$3500 on a manual GT (more if you upgrade clutch/tranny), and ~$4000 on an automatic GT, and that doesn't include labor costs.
243.5rwhp/284.2rwtq
Old January 16th, 2008, 11:50 AM   #32
95StangMX's Avatar
95 Mustang GT
can you please tell me where the hell you get the bs that you put in this post....easiest way to get a sure 300 HP is not to put together your own especially if you are not experienced with the parts first hand and only know what you have heard...a mismatched top end set made up of the most expensive parts out there can be wrong for you car and make it run like shit....I suggest talk to some people about the setups they run or buy one that is already matched up.. trickflows set is nice and simple and is all matched up for you... and what makes the AFR 165's the most proven and do you have a cam from ed curtis....why would you suggest him over Jay and camshaft innovations....because of experience with them or because of what you have read....I am running TFS heads and a cam from jay ....should have it together some time this week and will post up some numbers for you... the builder is guessing somewhere around 450
Old January 16th, 2008, 12:00 PM   #33
95StangMX's Avatar
95 Mustang GT
sorry not trying to sound like a prick but so many people get on here an post info that they have read in a magazine... and thats a quick way to blow some money....and as far as the cam I personally have not dealt with ed .... I have heard that he is pretty good.. I actually called him first and he was kinda rude told me once I knew all the specs to call back and hung up....if you are going with a simple top end then a package like the trick flow is a great setup....you could scrap the cam and get a custom grind for a few more ponies or use the one it comes with for now and if you decide to do more mods down the road then go custom grind....talk to some people on here about what they are running before you jump into anything
Old January 17th, 2008, 07:30 AM   #34
Bullitt95's Avatar
13.546 @ 105.32
Whatever the argument, the bottom line is that 235rwhp (210rwhp if you have an AODE) is the ceiling for basic bolt-on mods with stock H/C/I. To get 300+rwhp, you'll need to change at least the heads and intake (it's still achievable with the stock cam). TFS, Edelbrock, and Holley have matched heads/cam/intake kits while AFR only do heads so you have to match the cam and intake to them. You can put together your own combination but that doesn't guarantee 300+rwhp nor a good-running engine unless you've done some thorough research so you know what you're getting into. It is here where 95StangMX makes a very valid point.
243.5rwhp/284.2rwtq
Threads Similar to: Trying to hit my goal of 300hp...suggestions?
300hp burlingtonNC98GT 96-98 6 May 21st, 2007 09:26 PM
300hp stang5.0 5.0 Mustangs 5 April 21st, 2007 08:08 PM
My Goal is 400 RWHP...tell me what u think StuTheMusicEngineer 99-04 14 March 3rd, 2007 06:06 PM
Setting A Goal armadillon 5.0 Mustangs 23 November 17th, 2006 09:27 PM
