Trying to hit my goal of 300hp...suggestions?
Old April 12th, 2007, 12:50 AM   #1
too slow
95blackbeauty is on a distinguished road
Send a message via AIM to 95blackbeauty
OK...so this is what i decided. If i could get my car in the 300hp range i would be a happy camper. I have a 1995 5.0 HO and so far i have Full exhaust wit flow masters dumped at rear, 3.73 gears, short throw, CAI. I think i wanna add Ud pulleys, TFS, and stage two clutch. Think ill be close? What else could i do to tip the scale a lil bit. Besides the juice.
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
BOOSTED
Old April 12th, 2007, 01:10 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
a blower might help
Old April 12th, 2007, 01:17 AM   #3
too slow
tryin to get close as i can N/A...if i HAVE to add n20 then i will but i was just gonna see if anyone had some more advice.
BOOSTED
Old April 12th, 2007, 05:16 AM   #4
rj95svt is on a distinguished road
scat 331 stroker kit around 800 in summit! Go with the track heat kit and throw a trick flow stage 2 cam and shoot for 350hp at the rear wheels!
Old April 12th, 2007, 02:11 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Twisted Wedge heads, TFS stage 2 cam and TFS Track Heat or R-Series intake.
Old April 12th, 2007, 03:24 PM   #6
too slow
how hard is install on those heads? Cost?
BOOSTED
Old April 12th, 2007, 03:32 PM   #7
too slow
geez this is like major surgery...
BOOSTED
Old April 12th, 2007, 09:44 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Horsepower isn't cheap and if you've never installed heads before you probably want to have someone do it for you. You are looking at about $2000 in parts.
Old April 13th, 2007, 11:24 AM   #9
94' Cobra 351's Avatar
94' Cobra 351 is on a distinguished road
+1!
It would be very wise if you had a shop install the heads. I took the head off my mazda today to fix a spark plug that is jammed, and it's not that hard, but it will be easy to put back on b/c you just line up the timing marks and your set, but i'm not sure how you would get everything to line up if you go with a cam/head swap, but then again i have never done one.
if you do heads/cam/stroker kit, do it all at once, it will save you money on the labor portion. and if you can pull the engine yourself it will be cheaper
Old April 13th, 2007, 11:54 AM   #10
Euroeater95 is on a distinguished road
The hardest part of installing heads is adjusting the valves. If you decide to do it yourself, then one thing to make sure of is that you have at least .0100 between all three of the coils on the valve springs when it is fully compressed/valve fully open. Other than that it is pretty simple to adjust them, there are many different ways to do it. There are also plenty of sites on the net that give you a step by step.
Old April 13th, 2007, 12:06 PM   #11
too slow
i think im just gonna do TFS. 75mmthrottle body...will that hook up to my cold air? and ud pulleys maybe bigger maf and injectors. maybe a lil 50 or 75 shot of n20. What do yall think?
BOOSTED
Old April 13th, 2007, 12:28 PM   #12
I wouldn't go with nitrous, you can get your desired power out of that engine without adding n2o, but you could always have the nitrous just in case a new Z06 wanted to mess with you
Old April 13th, 2007, 01:34 PM   #13
too slow
Will a 75mm throttle body connect to my CAI?
BOOSTED
Old April 13th, 2007, 06:52 PM   #14
stang94 is on a distinguished road
Yes, my BBK 75MM TB did.
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old April 15th, 2007, 10:49 AM   #15
mustangman9550 is on a distinguished road
Just throw on some built heads! There ya go......
Old April 15th, 2007, 11:17 PM   #16
95wip is on a distinguished road
Send a message via AIM to 95wip
if put to the ground fairly well about what kinda times would this be running in a 1/4? aproximate
95' GT is being reconstructed!
Old January 9th, 2008, 03:29 PM   #17
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
high 12's low 13's with good suspension and good driver...
Old January 9th, 2008, 07:26 PM   #18
95StangSVT's Avatar
95StangSVT is on a distinguished road
300 on motor or RWHP -Intake manifolds (Holley systemax or so) Cam,injectors,Cold air intake,If you dont want to drop the money for new heads installed
Race you for your lady!!!!!!
95 Stang Svt
02 Suzuki GSXR
95 Nissan Hardbody Minitruck (Bagged)
04 Suzuki LTZ400 Quad sport
Old January 9th, 2008, 08:49 PM   #19
MikeD05GT's Avatar
2005 Mustang GT
heads and cams...intake...gears...full exhaust...bolt on bs....should see 350rwhp
Old January 10th, 2008, 08:14 AM   #20
Bullitt95's Avatar
1995 Mustang GT auto
13.36 @ 105.0
Bullitt95 is on a distinguished road
Stock is ~190-195rwhp on a 5-speed 5.0 GT.
With basic bolt-ons (CAI, MAF, TB, headers, midpipe, catbacks, pulleys) you'll have ~230-235rwhp.
You won't get beyond 235rwhp with the stock heads/cam/intake so to reach 300rwhp, you'll need to change at least 2 out of the 3 (heads & intake). You'll also need other supporting mods like a higher-flow fuel pump, bigger injectors, and a tune.
244whp/284wtq
Mod list in My Garage
Threads Similar to: Trying to hit my goal of 300hp...suggestions?
300hp burlingtonNC98GT 96-98 6 May 21st, 2007 10:26 PM
300hp stang5.0 5.0 Mustangs 5 April 21st, 2007 09:08 PM
My Goal is 400 RWHP...tell me what u think StuTheMusicEngineer 99-04 14 March 3rd, 2007 07:06 PM
Setting A Goal armadillon 5.0 Mustangs 23 November 17th, 2006 10:27 PM
