Clutch questions
Old November 26th, 2010, 08:03 PM   #1
Foxmoto28's Avatar
'94 GT Coupe
Foxmoto28 is on a distinguished road
Clutch questions
So I had my clutch replaced and afterwards the mechanic told me it would be another $100 to replace the clutch pedal adjuster? I passed for now but I noticed my clutch is STILL making noise as if the throwout bearing wasn't changed.
Is it true that after turning the flywheel and replacing the clutch it will make a noise for a few days? Not just quoting the mechanic on this one.
If this is normal will the adjuster be a fix? and can I do it myself?
Old November 26th, 2010, 10:19 PM   #2
centipede3001 is on a distinguished road
what year mustang do u have 1994-1998 have cable clutches and to adjust the cable you just reach down and pull up as hard as you can on the clutch pedal and that will adjust it and stop the sqweek
Old November 26th, 2010, 11:10 PM   #3
Foxmoto28's Avatar
'94 GT Coupe
1994 Mustang GT
I was told the quadrant is broken so I was planning on replacing it with an aluminum one. It should work the same way, right?
It would be this type.
http://www.americanmuscle.com/stdohoqu.html
Old November 27th, 2010, 12:14 AM   #4
correct
Old November 27th, 2010, 01:06 AM   #5
Foxmoto28's Avatar
'94 GT Coupe
Im still a little pissed after the fact I (for the first time) gave a shop a car of my own and paid good money for it; it still fucking squeaks. It's not squeaking like a champ but it's still slight.
I've been told that the triple hooks aren't good so would a single or double hook be best?
Old November 27th, 2010, 01:08 AM   #6
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
if youy are adjusting the clutch quad you pull up but you have to immediately push it to the floor or it wont adjust....and he is full or s##t...it shouldnt make a sound once new clutch is installed...
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old November 27th, 2010, 02:30 AM   #7
Foxmoto28's Avatar
'94 GT Coupe
Well I have asked multiple people whom have worked on a vast majority of cars and they said after turning the flywheel and replacing the clutch it may make some noise for a few days but the big thing is that adjuster is broken so I know that has some deal with the noise.
I'm going back tomorrow so I'll see what's up.
Old November 28th, 2010, 01:32 AM   #8
1994 Mustang GT
mustangmatt123 is on a distinguished road
what does the sound sound like? mines making a funny noise every time i accelerate. it happened right after i got my clutch replaced too. im pretty sure its the pilot bearing not properly greased.
Old November 28th, 2010, 08:43 AM   #9
1995 SVT Cobra
Cobraman1024 is on a distinguished road
the pilot bearing is a sealed unit; if there is any grease in it, it should be internally with the needles inside. I might grease the input shaft a little bit before poking it into the pilot bearing.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old November 28th, 2010, 11:20 PM   #10
Foxmoto28's Avatar
'94 GT Coupe
I can't really describe it but it's like the throwout bearing is out. But at times I hear a humming noise whenever I accelerate at top speeds. The mechanic that worked on my car ended up getting fired over my car and will be going back in this week. Possibly money coming back to my wallet.
Old December 17th, 2010, 01:39 PM   #11
Foxmoto28's Avatar
'94 GT Coupe
It ended up being the pressure plate (collapsed).
Two weeks later, lots of yelling and threats and I have a brand new clutch that works great.
Motherf**ker ran my yellow top in the ground though! Thank God for three year warranties!
Old December 17th, 2010, 01:41 PM   #12
2000 gt
Did they fix it at their expense I hope
Crew Member # 3
Old December 17th, 2010, 02:06 PM   #13
Foxmoto28's Avatar
'94 GT Coupe
Oh yes. They were trying to tell me it would be about as much as they charged me before to put in a new one (perfectly new clutch that THEY scrapped). They ended up put it in for free that day.
For the future reference; if you don't have time to do it yourself like me, don;t go to Eagle Transmission.
Threads Similar to: Clutch questions
clutch questions PureEnergi 5.0 Mustangs 18 November 17th, 2010 06:59 PM
Clutch questions 91Mustang GT 5.0 Mustangs 3 September 20th, 2010 01:58 AM
clutch quadrant/ clutch questions 92ponylx 5.0 Mustangs 6 August 23rd, 2010 12:49 PM
Clutch Questions JRCEngineering 99-04 0 August 17th, 2010 11:01 AM
clutch questions tweeters97 4V / SVT 22 March 24th, 2009 07:54 PM
