Aluminum Driveshaft Y/N - Forums at Modded Mustangs
post #1 of 11 Old November 30th, 2010, 10:46 PM Thread Starter
Hedobob's Avatar
Send a message via AIM to Hedobob
Is it worth putting an aluminum driveshaft in my 95 Mustang GT? Its a heavy car and shedding 20lbs off it couldnt hurt but is it a big upgrade and improvement for the money?
Hedobob is offline
post #2 of 11 Old December 1st, 2010, 02:27 AM
Resident Headbanger
Bullitt95's Avatar
If you're doing it for the 9lb (not 20) weight saving alone, don't bother. You only need an aluminium driveshaft if you swap in steeper rear axle gears.
The reason is that the steeper gears lower the road speed at which the driveshaft reaches its critical speed (where harmonic vibration begins to occur). A lighter driveshaft will have a higher critical speed so you can reach a higher road speed before it starts to vibrate.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #3 of 11 Old December 2nd, 2010, 04:04 PM
justi88's Avatar
Send a message via MSN to justi88
you mean if i get some 3.73 gears it would be wise to get an aluminium driveshaft??
justi88 is offline
post #4 of 11 Old December 3rd, 2010, 01:31 AM
Not to invade the thread or anything but is it bad to have 373 gears and the stock driveshaft ?
centipede3001 is offline
post #5 of 11 Old December 3rd, 2010, 01:38 PM
not really. but like 4.10 gears its a good solution
mustangmatt123 is offline
post #6 of 11 Old December 3rd, 2010, 01:43 PM
Priest of the Car Gods
ReverendDexter's Avatar
Good mod, but there's better ones to do beforehand.
Function > Form, always
ReverendDexter is offline
post #7 of 11 Old December 3rd, 2010, 03:04 PM
June 2010 ROTM
Serlin's Avatar
Alum. DS is kinda like pulleys. Slight difference, but when you put all these mods together, they can add up to some good weight savings / hp.
Also, when your under there, you can remove the huge hunk of metal under the rear end. Its very heavy, and just there to cut down on NVH. You dont need it at all. Its probably 20-30lbs.
HPDE Instructor: NASA, PCA, HOD, PDG, Track Guys
www.RaceCarTowHooks.com
My Track Videos http://www.youtube.com/user/Msirlin
My Garage page: http://www.mitchsirlin.com/mustang/index.htm
Serlin is offline
post #8 of 11 Old December 3rd, 2010, 05:47 PM
yeah i removed mine a while ago
post #9 of 11 Old December 4th, 2010, 07:54 AM
Resident Headbanger
Bullitt95's Avatar
Yes. The higher ratio axle gear will increase the driveshaft speed at any given road speed so yes, a lighter driveshaft would be beneficial.
post #10 of 11 Old December 4th, 2010, 07:57 AM
Resident Headbanger
Bullitt95's Avatar
That "dogbone" weighs 9lb and you can indeed remove it without issue, but make sure that you leave the pinion snubber and bracket in place.
post #11 of 11 Old December 4th, 2010, 08:40 PM Thread Starter
Hedobob's Avatar
I have 3:73 gears plus im upgrading what can be done then ill modify the engine all at once in the mean time ive done almost everything else but the fuel pump. I did buy the driveshaft and installing it next week
Hedobob is offline
Human Verification
