EGR Blockoff plate?
Old December 3rd, 2010, 01:57 AM   #1
wildhorse95's Avatar
1995 Mustang GT
N\A
wildhorse95 is on a distinguished road
EGR Blockoff plate?
Ok my buddy has a 1995 mustang gt like mine but stock. He wants to take his EGR valve off and jegs has a blockoff plate for it? Wha will happen if we take this off? Can we just take it off and everything work just fine or will it piss off the car?
I heard it would make the check engine light come on.
1995 Mustang GT
2002 Ducati Monster 750 i.e. Dark
Old December 3rd, 2010, 11:09 AM   #2
95project is on a distinguished road
it will make it run like total crap because more air will be entering the engine that the ECM thinks...i made a plate for mine that works fine.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old December 4th, 2010, 03:01 AM   #3
1995 Mustang GT
N\A
So if he deletes the EGR and puts the blockoff plate on it will run just fine?
1995 Mustang GT
Old December 4th, 2010, 04:46 AM   #4
2001 Mustang GT
DsmDave is an unknown quantity at this point
you can get the car tuned to remove the egr
Old December 4th, 2010, 09:21 AM   #5
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
his car will run like crap until he gets it tuned, it will increase his cylinder temps, could cause spark knock.. and will cause his gas mileage to go to shit.
leave it where it is. Its not hurting anything
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old December 6th, 2010, 01:17 AM   #6
1995 Mustang GT
N\A
ok thanx he decided not to mess with it anyway
1995 Mustang GT
Old December 6th, 2010, 11:54 AM   #7
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
Adder this is not true for every car. I always hear half the people say it does not affect it and the other half say leave it alone cause it does. Me being the way I am I said screw it, one way to find out, and took off the egr and got one of those egr delete plugs for it. I felt no difference in performance. I recently went and got my car tuned, I figured they would tell something was off with the car being that i deleted the egr. The guy told me that with my car there was really no need to connect it to a computer. He said to tune my car we just need adjust fuel and timing.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old December 7th, 2010, 12:28 AM   #8
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Same here. I removed my EGR a long time ago. I made my own block off plate for the TB elbow and plugged an EGR eliminator simulator into the wiring harness. No check engine light, no driveability issues, same performance, same gas mileage, and no.4 spark plug became much easier to remove.
Threads Similar to: EGR Blockoff plate?
EGR block off plate orangestang42 5.0 Mustangs 5 October 14th, 2010 11:12 PM
EGR PLATE preston.rucker 5.0 Mustangs 9 May 10th, 2009 02:35 AM
machining egr plate 86gter 5.0 Mustangs 3 March 24th, 2008 01:23 PM
EGR Restrictor Plate smokiebear911 5.0 Mustangs 2 March 21st, 2007 12:17 PM
