'94 GT Coupe
Turn signals/hazards
Had my '94 GT in the shop to have my clutch replaced (what a pain in the ass that was!) now I'm having troubles with my turns and hazards.
I found that a 25a fuse was blown so I replaced it; everything was working fine and then I started it up and fuse blew again. Next I replaced the fuse with a 30a and replaced the relay and now they still aren't working. help? |
Hardon Enflooziast
Sounds like you got a short somewhere...
![]() Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines, |
'94 GT Coupe
I'm not sure where I need to be looking.. I'm going to try and check the Multi-function lever in the steering wheel down to the fuse panel and so on.
'94 GT Coupe
It's only going on whenever the clutch pedal is pushed in
'94 GT Coupe
1995 SVT Cobra
there is a switch on the clutch pedal that completes the ignition circuit when you go to start the car. Thats why its happening only when you push in the clutch pedal.
There is a short somewhere in the wiring on your ignition column----very good possibility it is in the combination switch stalk itself. do you have any issues with your headlights?
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
#7 | |
'94 GT Coupe
1995 SVT Cobra
Is yours an American car or a Canadian car? Canadian car would have a daytime running light module which has the wiring for your foglight/horn fuse. Could also be your clutch quadrant if you replaced it with an aftermarket metal quadrant.
#9 | |
'94 GT Coupe
If it is a canadian; where's the module located? |
Threads Similar to: Turn signals/hazards
| Red Turn Signals? | HurrycaneStang | 2005 - 2010 | 12 | July 30th, 2010 01:40 PM |
| no turn signals/brake lights/hazards | 2tall4my94 | 94-95 | 7 | May 31st, 2010 11:55 PM |
| Turn signals again | dr.gonzo! | 5.0 Mustangs | 1 | March 23rd, 2010 11:11 AM |
| Turn signal/Hazards Don't Work | Justdoit04 | 99-04 | 6 | July 18th, 2009 02:19 PM |
| turn signals | harrylee | 5.0 Mustangs | 3 | May 13th, 2008 10:06 PM |
