reverse lights
Alright guys I've had this mustang for a little while and never noticed it. I have a 94 vert with the 96+ tail lights. Just noticed today that my reverse lights don't come on. Is there a certain fuse I need to check or what?
1995 SVT Cobra
Not 100% sure if the wiring harness is a little different when a 94/95 replaces the taillights with the 96-98 style but in case everything is the same, check the switch on the drivers side of your T-5 transmission (assuming you have the 5-speed manual). The connector for that switch should have a round black rubber boot over it about the diameter of a quarter. When you pull this plug off the connector, there should be two studs sticking out-----that is your electrical connection for the reverse lights. Refer to this photo: Google Image Result for http://www.allfordmustangs.com/forums/attachments/5-0l-tech/58773d1231794341-reverse-light-switch-location-t5_trans_electronics.jpg
The one you want in the photograph is labeled "reverse gear switch". make sure the electrical plug is connected properly (wiring going into the plug will be at about the 6 o'clock position). Another possibility is that the switch itself has failed.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
i dont think there is gonna be a fuse just for the backup lights, i would check the connections and then the bulbs also
315's Crew Black and White Crew Crew Member #2
Alright, well one of my tail lights are tinted, and the other one isn't so it looks goofy...I have the horizontal ones that are like brand new..I think I am going to put them back in, even though i like vertical ones a lot better. I will check the bulbs while I am at it. Then if that checks out good I will check the connections to the tranny. what fuse is the tail lights on? maybe something else isnt working, just something I could check.
#5 | |
1995 SVT Cobra
I meant to say reverse lights. But there still may not be a fuse for them. My tail lights are working just not reverse lights
Alrighty, My horizontals are in worse shape than I thought. I am going to buy another tail light to match my tinted one. I checked my bulbs and they were good, so I assume that it is the wires going to the t5 tranny, which I haven't checked yet. I will do that on a lift when I have a chance instead of crawling under the car.
#8 | |
1995 SVT Cobra
95 mustang gt
your reverse lights share the turn signal fuse found that out on my old 95 kept blowing fuse when you put it in reverse it turned out to be the switch on the trans
Threads Similar to: reverse lights
| no reverse lights | brandywine112972 | 96-98 | 4 | October 25th, 2010 08:26 PM |
| LED Reverse Lights | iceguyb14 | 2005 - 2010 | 10 | September 23rd, 2010 07:00 PM |
| Reverse Lights | VM0824 | 5.0 Mustangs | 5 | March 30th, 2010 03:59 PM |
| No Reverse Lights | 04BLKGT | Modular Mustangs | 7 | September 9th, 2009 09:35 PM |
| No reverse lights | yellowstang6r | Audio/Video | 10 | November 4th, 2008 08:50 PM |
