LinkBack (1) | Thread Tools |
#1
1995 Mustang
Headlights flicker by themselves
Hello, I am having a pretty serious issue with my headlights flickering on and off by themselves. Its really odd, it first did it about a month ago and has not done it again until this week.What they do is flicker and then turn off for maybe 15-20sec and then turn back on,once back on for maybe 30sec or so they repeat the process,while sometimes flickering wildly.Please help me, I cannot drive my car at night like this.
1995 SVT Cobra
The combination switch that holds your turn signal/windshield wiper controls is the first place I'd look. The 12v source for the headlights goes through there.
Second place would be the headlight switch itself but its less likely to be at fault than the combination switch.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
1995 Mustang
Thank you,I will check that tomorrow.
1995 SVT Cobra
You're better off just replacing the thing with one from a junkyard. Not much you can do as far as troubleshooting it. I have disassembled, cleaned and reassembed the combination switch in all three of my cars to fix this problem. You can try the same rather than shelling out $80 or so to replace it with a new one. Its very easy, just make sure you reassemble it the exact way it came apart. Use a very fine grit sandpaper to clean the copper connections inside until they are shiny.
1995 Mustang
OK then I will try and clean the switch and see what that does,if that does not fix the problem then I will buy another switch.Thanks for the help.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/197306-headlights-flicker-themselves.html
| Thread Headlights flicker by themselves | Forums at Modded Mustangs | BoardReader | This thread | Refback | March 11th, 2012 12:52 PM | |
Threads Similar to: Headlights flicker by themselves
| Headlights! DONE with ebay headlights!!! | Saleen0101 | Modular Mustangs | 11 | December 30th, 2010 02:18 PM |
| converting my 85 LX headlights to the later model fox body headlights | pd411 | General Car Care & Detailing | 0 | January 11th, 2010 10:53 PM |
| HID flicker then shutoff problem...help!!! | The Black Car | V6 Mustangs | 12 | June 27th, 2009 02:50 AM |
| projector headlights vs regular headlights | BossOfDaRich | V6 Mustangs | 7 | June 22nd, 2009 09:57 PM |
| head lights flicker on my 89 | White 89 | 5.0 Mustangs | 19 | August 25th, 2008 02:43 PM |
