Rear Defroster on vert
Old December 27th, 2010, 12:35 AM   #1
matholland is on a distinguished road
On my vert, If i hit the button for my rear defroster, the light on the button comes on, but it does not seem to work as far as defrosting my rear window. Whats something to check?
Old December 27th, 2010, 03:29 AM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
check to make sure both contacts and leads are connected to the window itself. If they are, disconnect them and put a DVOM between the two leads and check for power, when he button is pushed in.
If you have power, suspect the tracers on the window are bad. If you dont have power, check your fuses, then suspect your wiring.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old December 27th, 2010, 02:24 PM   #3
Dumb question. But what is dvom?
Old December 27th, 2010, 02:36 PM   #4
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
mine works but not very well, only really clears half the rear window
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old December 27th, 2010, 03:03 PM   #5
digital volt/ohm meter
[SIGPIC][/SIGPIC]
Old December 27th, 2010, 03:39 PM   #6
ohh lol ok I got you. I plan on heading home, and doing my tail lights, and my window here in about an hour, I will post back and let you guys know what I find out
Old December 27th, 2010, 03:47 PM   #7
i wont be up, its damn near midnight here
[SIGPIC][/SIGPIC]
Old December 27th, 2010, 04:42 PM   #8
Alright, well there is nothing going to my rear window..that explains why it isnt working..there is no prongs or nothing on it. Who knows where the wires are at...Is there one of those things I can buy for the window somewhere?
Old December 27th, 2010, 11:36 PM   #9
1995 SVT Cobra
Cobraman1024 is on a distinguished road
ok, so your back glass does not have the metal prongs on it that the connectors attach to? and you don't have connectors/wiring coming out of your interior trim panel? The panel that your coat hangers are screwed to, is there a little notch in the plastic right up next to the back glass?
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old December 30th, 2010, 05:11 PM   #10
does not have the metal prongs..I do not have coat hangers, I have a vert
Old January 2nd, 2011, 10:44 AM   #11
1995 SVT Cobra
I just checked with my friend but I don't think convertibles came with rear defrost. Do you have the black lines going across your back window? I know the yellow guy up above has it on his 99-04 car but maybe the 94-98 verts didn't have it.
sold: 1987 GT
Old January 7th, 2011, 04:49 PM   #12
I have a factory switch for rear defrost, and there is lines..but someone told me that since my rear window is tinited, they probably took it off, because the rear defroster will make the tint peel off
Old January 12th, 2011, 10:09 PM   #13
1995 SVT Cobra
I have tint on both of my Cobras which have factory installed rear defrost; never had a problem with the tint coming loose if its done properly by the tint installer.
sold: 1987 GT
Threads Similar to: Rear Defroster on vert
Rear defroster not working brimmer555 5.0 Mustangs 3 November 21st, 2010 10:07 PM
Rear Defroster zinc02GT Audio/Video 3 January 15th, 2010 12:28 PM
Rear Defroster weems 99-04 16 November 27th, 2009 11:18 PM
Rear defroster 92ultrablue 5.0 Mustangs 3 November 3rd, 2009 08:16 AM
rear defroster skuzzy 96-98 5 August 21st, 2008 12:46 AM
