Suggestions for 5.0 replacement
Hello
I am buying a 95 GT convertible with an auto trans that has a bad engine. I was going to find a 94 or 95 engine but my buddy with a 03 Cobra said any later year mod engine bolts in with the computer/harness. On another forum I was told the Explorer engine has better heads and intake than stock Mustang 5.0, is that a simple swap? I haven't done a swap before so want it as simple as it can be. Thanks Joe |
the explorer 5.0 is a direct replacement
and its actually smog legal too *edit* and your buddy fed you a plate of lies. clearly hasnt got a clue. You would need a new K-member, and a new transmission. Not to mention a completely different wiring harness and computer system.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
This is nice to know that the explorer 5.0 will bolt right up. Just in case I gotta find a motor some day
you might have to change the oil pan and pick up tube, infact im almost positive you will.
also i highly doubt the accessory brackets on the exploder will be the same as the brackets on the mustang so you will have to swap them over too.
315's Crew Black and White Crew Crew Member #2
thats why you only use the longblock... genius
1988 Notchback
11.19 @ 122mph N/A
Adder may sound like an asshole, but I have learned from his wisdom in the past on another forum. He's good people and he knows his shit!!!!
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
just warning anyone reading because there are some out there who might try to go to the junk yard and get an entire engine accessories and all and try to drop it into their stang and get mad that it isnt a direct drop in
and thanks i consider myself a genius too lol
The Explorer engine does indeed have better heads/intake but it also has a milder cam than the Mustang GT. It's a simple swap as long as you use only the long block engine with intake. Just bolt your existing accessories to it.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Threads Similar to: Suggestions for 5.0 replacement
| Suggestions for a new daily/stang replacement | tfofkyle | All Other Vehicles | 9 | July 28th, 2010 02:04 AM |
| Engine Replacement Suggestions | jake1191 | 99-04 | 24 | June 28th, 2010 09:23 AM |
| Suggestions on replacement head unit? | SoCalGT2005 | 2005 - 2010 | 16 | October 29th, 2009 10:39 PM |
| Replacement wheel suggestions??? | elund126 | 99-04 | 15 | May 27th, 2009 04:53 PM |
| AC replacement | motorhead6776 | V6 Mustangs | 5 | May 30th, 2008 01:51 PM |
