95 carb swap
Old December 27th, 2010, 08:11 PM   #1
ggreene is on a distinguished road
95 carb swap
I just bought a 95 GT. The car itself in is pretty good shape. The best part being it came with a new 347 short block, victor junior intake, t-5, and gt40 heads. The motor was disassemled very slopppy. I think it would be impossible to try and go bakc EFI, atleast for somone with my know how. I am wanting to change it over to carb, make the motor as simple as I can. What options do I have for ignition? again I am wanting simple. I have a brand new MSD Distributor PN#8455 but if im correct this is for EFI only.
Old December 27th, 2010, 10:01 PM   #2
1995 Mustang
laser95 is on a distinguished road
I think I should be able to help you out here. I swapped my 95 v6 car to a 5.0 using a 95 gt motor, which of course was orignally efi. I went carb, using an HEI style ignition(GM style with built in coil) and mallory #4309 fuel pressure regulator so I could use the stock fuel pump.
Threads Similar to: 95 carb swap
carb swap 90mustang50 5.0 Mustangs 5 June 22nd, 2010 02:59 PM
how to swap from EFI to carb? demonicus 5.0 Mustangs 13 January 16th, 2010 04:16 PM
EFI to Carb Swap 98stangv6 94-95 0 September 12th, 2009 12:12 PM
FI to carb swap on 5.0L H.O. TN.Frank 5.0 Mustangs 3 April 4th, 2009 10:48 AM
EFI to Carb swap? JONJON 5.0 Mustangs 3 September 22nd, 2007 05:54 PM
