Experience with a draw
I have had a draw that will drain the battery in a couple of days if not driven or charged. I was wondering since I really haven't been able to trace it down, what experience others have had with a draw on our vehicles. I do not have keyless entry so I know it isn't the module. I have traced all grounds and they all appear good and the ones that I questioned I cleaned and/or ran a new one. Any experience or advice will be greatly appreciated.
'Nikstang' GonzoMotorsports Mod List: http://www.gonzomotorsports.com/?page_id=236 |
remove your negative battery cable and attach a test light between the cable and terminal. If you have a draw, it should light up. The open your fuse panel under the hood and start pulling fuses one at a time.
If the light goes out, the draw is in that circuit. Do the same test with the panel under the dashboard... remember to have your drivers door closed though. A second set of eyes will greatly help here, as you wont easily be able to get out from under the dash.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
do exactly what adder mentioned and once you narrow it down to a circuit get a wiring diagram and find out what devices are on that circuit and start unplugging them one by one till you find out which device it is then get a new one or leave it unplugged.
315's Crew Black and White Crew Crew Member #2
Threads Similar to: Experience with a draw
| draw my thing | graystang01 | The Clubhouse | 13 | May 16th, 2010 03:22 PM |
| who can draw? | CobraPhoenix | Chopshop | 0 | March 2nd, 2010 11:08 PM |
| BPV on a Draw-Thru Set Up? | weems | 99-04 | 11 | October 13th, 2009 09:37 AM |
| lemme draw on yalls experience | ford6693 | 99-04 | 25 | November 29th, 2008 08:39 AM |
| Can Anyone Draw? | ZoomZoomMFer | The Clubhouse | 17 | June 5th, 2008 08:45 AM |
