How do you identify stock heads
Old December 31st, 2010, 12:08 AM   #1
ggreene is on a distinguished road
I was wondering what was the factory imprints for stock heads, how do you tell the difference from gt40 and gt40p? what about e7?
Old December 31st, 2010, 12:12 AM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
search, weve covered this on great depth here on this forum
here, i did the work for you
heads and cam question
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old December 31st, 2010, 12:49 AM   #3
Thanks, I tried to search, but did not find anything with any numbers like mine. On the top of the heads the only thing I can find is Windsor and a W, then I see a 92 and between two of the rocker I see .051. On the outside I have a few different fine stamps that say Gurkeys, sv47, lee C, And what looks to be EDD1E
Old December 31st, 2010, 07:21 AM   #4
soulds like you might have World heads... post pictures
[SIGPIC][/SIGPIC]
Old December 31st, 2010, 10:52 AM   #5
yep, I stayed up till 3am last night trying to find out what they were, I finally found out they were world product 200cc windsor senior. I know that aluminum heads are better, but are theese a good heads just for a street car. Do theese heads work good with my combination? The setup I have is Keith black 347 stroker kit in stock block, The windsor 200cc sr heads, f303 cam (I know this should be changed out later, but will have to do for now) Parker funnel web intake, Mac shorty headers. I played around with my stock mustang when I was younger, but I want to putthis motor together right. Dont have a huge budget, but have time to save up for what I need.
Old January 1st, 2011, 12:51 AM   #6
Those are definitly a good set of heads. Get a custom cam ground for your setup and you'll be all set.
[SIGPIC][/SIGPIC]
Old January 1st, 2011, 11:37 PM   #7
With fly cut pistons, what would you recomend for the lift?
Old January 2nd, 2011, 06:40 AM   #8
lift is irrelevant if its not accompanied by the correct valve timing events.
Contact a custom cam grinder...
[SIGPIC][/SIGPIC]
Threads Similar to: How do you identify stock heads
replacing stock 302 heads with windsor 351 heads - questions Tootheroots 5.0 Mustangs 5 April 15th, 2010 10:51 AM
Can Anyone Identify These Heads? mr garrison 5.0 Mustangs 21 April 19th, 2007 01:35 PM
