94 5.0 302 gt
in the making
400hp 302 vert please help
I posted in the 5.0 forum, i have a 1994 gt 302 true ho,fresh rebuild with forged pistons,new rings,bearings,etc edelbrock performer rpm 202 heads,very mild cam for drivabilty,trick flow street heat upper and lower intake,24#injectors
![]() So here is the problem,it will start everytime and run allday untill you turn key off,then it will start right back,run then die like you turn the key off. ![]() so i check for fuel,spark,compression fuel-32-40psi ideal, when dies holds 38 spark present at coil, dizzy,wires,plugs,before it dies and after. replaced-tps,iac,module on the finder"tfi i think" checked the spout to see if injectors where pulsing,yes ![]() so please somebody help me with this thing my ASS.
1999 mustang cobra
![]() iTrader: 1 reviews
might be a bad connection on the ignition
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
Threads Similar to: 400hp 302 vert please help
| Quickest 400HP | humboldt9r | 96-98 | 20 | January 5th, 2011 06:39 PM |
| 400hp gt vert will not idle after it is warm | tranram | 5.0 Mustangs | 22 | January 5th, 2011 12:27 AM |
| need a cam to get more than 400hp on this 302 build | stangdesign | 5.0 Mustangs | 4 | October 4th, 2009 06:00 AM |
| 400hp 289? | Vinyl66 | Classic Mustangs | 88 | September 28th, 2008 05:25 PM |
| new m3 v8 powered...400hp+ | jat | 2005 - 2010 | 7 | April 21st, 2007 11:11 AM |
