tranny drop
Old January 6th, 2011, 07:42 AM   #1
1994 Mustang GT
mustangmatt123 is on a distinguished road
tranny drop
hey all, yesterday I have had enough with the noise coming from my transmission, so I went ahead and jacked it up. It took me an hour and a half to securely jack it up, (not including looking for 4 bricks and replacing 2 bricks)I have gotten several opinions on what is making the noise, and going with the pilot bearing being old. I have a installation guide for a clutch to help me, but I'm having a problem with gettin the midpipe off. the guide doesn't mention me needing like 6 extensions to reach it. anyways I'm gonna go get more extensions after work, then see if i can reach the damn bolts on it.
I just want to make sure I'm doing this right. I'm only 16 and have no one helpin me, and I don't want to take it to a shop and spend 300+ dollars when it will take me 20 dollars at most. here is the link to the guide(s) I'm using: RAM HDX Clutch - Installation Instructions at AmericanMuscle.com - Free Shipping! and Mustang RAM Clutch Kit (86-04) - Installation Instructions at AmericanMuscle.com - Free Shipping!
if anyone wants to throw their 2 cents in its welcome, and very much appreciated. I can get pics of where I'm at on the project if anyone needs them
Old January 6th, 2011, 07:59 AM   #2
castine917's Avatar
95gt,67maro,05sti....
14.8@93,13.6@101,
castine917 is on a distinguished road
those instructions look pretty accurate and detailed.
spend another 25 on jack stands! bricks aren't the safest. look for a swivel socket to make it easier on you. one like this ball and socket is best. IPM80A, Universal Joint, Power, Swivel Ball, Lock Button, 1 3/8"
one like this u joint type jams and isn't worth it. Sears: Online department store featuring appliances, tools, fitness equipment and more
Old January 6th, 2011, 08:10 AM   #3
1994 Mustang GT
I have a swivel joint, but only one. Do I need more?
Old January 6th, 2011, 08:26 AM   #4
1995 SVT Cobra
Cobraman1024 is on a distinguished road
You should only need a 3/8 swivel joint.
I didnt read through the AM instructions but it took me an hour and a half (with the car on jackstands and using hand tools instead of air tools) on my 95 Cobra to have the T5 on the ground and about an hour when I removed it on my 95 V6 Mustang. The most difficulty if you are not using air tools is removing the driveshaft bolts (super tight usually) and the h-pipe to header nuts which are usually effected by the exhaust heat (I call it heat-welded). Other than those two things, its pretty easy.
EDIT: just checked out the AM instructions. They are for a new edge mustang with a T45 manual trans.
The easiest way I have found to drop a T5 is to remove the two 13mm bolts holding the trans crossmember to the car frame with it being supported by a jack. Lower the transmission until you have clear acces to the four 15mm bolts that hold the trans to the bellhousing. Remove those four bolts and pull the trans toward the back of the car and lower it using the jack. Remove the starter and clutch fork from the bellhousing and then six 15mm bellhousing bolts. You can actually tilt the engine down towards you a little bit by grasping the bellhousing through that large center circle opening---this allows you to see the top two 15mm bolts easier. Once bellhoising is off, install the clutch alignment tool into the center of the clutch before removing the pressure plate bolts----makes it easier to remove the pressure plate and clutch disc as an assembly and prevents the pressure plate from falling on you once the volts for it are removed.
When you remove the flywheel, there is a large thin metal adapter plate behind it; DO NOT forget to reinstall this onto the engine dowels before putting the flywheel back on!!!!!
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old January 6th, 2011, 08:33 AM   #5
1994 Mustang GT
wait...how the hell did you get your air tool to get to the headers/midpipe bolts? I'm at a dead end because there are like 2 places that I can reach the bolts and between shit getting in the way and the swivel just swiveling off the bolt I cant seem to get them out. the bolts on the inside were easier, but I'm at a loss on how to get the outer bolts off
Old January 6th, 2011, 08:55 AM   #6
1995 SVT Cobra
One other thing. While you have the flywheel off is the optimum time to replace the crankshaft rear main seal if you have an oil leak there (most 5.0 engines are leaking there)
sold: 1987 GT
Old January 6th, 2011, 08:58 AM   #7
1995 SVT Cobra
I dont remember if I had to use a swivel for those outside nuts or not on my Cobra----- I have longtube headers now so its easier to get to the midpipe nuts.
On the v6 you could just access them with long extensions, no swivel needed.
sold: 1987 GT
Old January 9th, 2011, 09:27 PM   #8
88 Mustang lx
marshall88lx is on a distinguished road
def invest in some jack stands!
Old January 9th, 2011, 10:02 PM   #9
ryanw's Avatar
1991 Ford Mustang GT
DONT USE BRICKS....They will break under the weight of your car. WHAT ARE YOU TRYING TO DO KILL YOUR SELF ? Im sorry if im coming across as a dick, but many people have died doing shit like that. I know its already been said but ill say it to. GET JACK STANDS
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 10th, 2011, 01:04 AM   #10
s351r13's Avatar
1996 Saleen S351
s351r13 is on a distinguished road
Ditto!
96 S351 #13
99 S351 #14
99 S351 #46
94 S351 #35
95 S351 #43
00 S281 #417
02 S281SC #117
Old January 10th, 2011, 07:26 AM   #11
1994 Mustang GT
i got 2 jacks in the front, and bricks with wood on top in the back. anyways im thinking about quitting before i actually drop the transmission, and take it to a shop. thing is pissing me off soo much i dont care about the money...i just want it fixed
Old January 10th, 2011, 12:25 PM   #12
castine917's Avatar
14.8@93,13.6@101,
get jacks for back too!
Old January 10th, 2011, 09:13 PM   #13
1995 SVT Cobra
Your choice...........just don't go to Firestone, they charged me about $600 8 years ago------just that was enough to kick my ass in gear to learn how to do it myself. Last year alone I removed/installed T5's about 5 times for clutch changes in three different 94/95 mustangs lol......
sold: 1987 GT
Old January 12th, 2011, 02:32 PM   #14
1994 Mustang GT
yeah I put everything back together. someone told me you needed a gasket for the headers to the midpipe, but I dont see any residue of an old one. is this true?
Old January 12th, 2011, 02:58 PM   #15
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Latemodels dont use collector gaskets, we have ball and socket connections no need for a gasket.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old January 12th, 2011, 09:47 PM   #16
1995 SVT Cobra
If you have an aftermarket header/h-pipe combination or longtubes, it might be worth it to use some Permatex Ultra Copper gasket maker. Sometimes the aftermarket headers and h-pipes don't seal up perfectly with just the two studs/nuts at the collectors.
sold: 1987 GT
Old January 12th, 2011, 09:48 PM   #17
1995 SVT Cobra
The 96-98 Cobra supposedly uses a collector gasket on the passenger side. I haven't taken my '96 Cobra apart to verify this yet though.
sold: 1987 GT
Old January 13th, 2011, 10:55 AM   #18
95opal's Avatar
95 opalfrost gt
Yes the mod motors use a gasket but this isnt the mod forum its the 94-95 section. So lets try and keep it simple for the guy he dosent have a mod motor.
5.0 magazines
Old January 13th, 2011, 01:46 PM   #19
1994 Mustang GT
one more question, does the headers have a flange on it that moves? cause i dont remember the holes for the bolts being where I cant put them in at. If i can get pictures later I will
Old January 13th, 2011, 01:55 PM   #20
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
If you're doing this by yourself, have fun dropping the transmission. Me and my Dad did it and it was not fun...When we dropped it, my Dad recently had shoulder surgery and he could not use his arm at all. It is quite awkward if you ask me.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: tranny drop
Please God... Drop it hard, drop it fast dr.gonzo! The Clubhouse 37 December 9th, 2010 12:27 PM
Tranny shifts hard - tuner frys tranny/engine? tangbang V6 Mustangs 4 May 27th, 2008 01:09 PM
Tranny Drop zinc02GT 99-04 20 March 24th, 2008 02:00 AM
LTs With A Drop RandoGT 96-98 4 December 3rd, 2007 03:51 PM
Engine Tranny Drop In WAR-PARTY 99-04 1 November 2nd, 2006 03:09 PM
