70mm mass air flow 94/95 Mustang GT 5.0 19lb SN95 MAF
Old April 17th, 2007, 01:42 PM   #1
stang94 is on a distinguished road
How hard is it to recal this to 24lbs?
Any idea how much it will cost?
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old April 17th, 2007, 02:59 PM   #2
mustangman9550 is on a distinguished road
On the maf I believe all you have to is swap out the little air tubes, think they're called test tubes in there for the correct poundage of fuel injector as long as it's aftermarket maf.....
Old April 17th, 2007, 05:21 PM   #3
call me dumb, can you explain that again for me. All I gotta do is put bigger tube?
Old April 17th, 2007, 05:33 PM   #4
EXAMPLE:
http://store.summitracing.com/partde...5&autoview=sku
...and sorry, they're called sample tubes!
Old April 17th, 2007, 05:46 PM   #5
So to recal from 19 to 24, thats all I need to get?
Old April 17th, 2007, 06:41 PM   #6
Euroeater95 is on a distinguished road
I thought that it was all in the electronics, but if that is all you need I am a dumbass
Old April 17th, 2007, 07:45 PM   #7
The sale is ending in less than 2hrs, I need to know how hard is it to recalibrate. I currently have 19lbs injector on the car so that will work fine. I'm doing H/C/I later TFS top end, and will upgrade to 24lbs. I'm getting this for only $30 used. So when I upgrade to 24lbs, I dont want to get another one, can i just reclab this. I need to know how can it be done though.
Old April 17th, 2007, 09:20 PM   #8
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
You have a 70mm MAF already. If your refering to the 73mm C&L i would just stay away. You really will not see a gain from a MAF. Use the stocker until you do HCI, or up injector size.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old April 18th, 2007, 07:31 AM   #9
ok, thanks
Threads Similar to: 70mm mass air flow 94/95 Mustang GT 5.0 19lb SN95 MAF
mass air flow question arice 94-95 5 May 7th, 2007 02:24 PM
mass air flow arice 94-95 2 March 30th, 2007 12:12 AM
mass air flow FastBack71 5.0 Mustangs 1 February 1st, 2007 08:33 PM
Mass Air Meter Question (Cobra 70mm) Help cobraetti 5.0 Mustangs 0 October 30th, 2006 06:52 PM
