1995 Mustang GT
I have a fuel question
I searched and I couldn't find what i was looking for. I want a to supercharge my stang but i only want to run like 8 psi maybe. I am wanting to do this cheap. (I know cheap is bad but i don't care lol) So here is my question. With only running 8 psi could I skip the injector upgrade and get an FMU to compensate? That is what the Vortech kit does. Is this a bad idea if i am money limited?
1991 Ford Mustang GT
Upgrade your fuel pump to a 255 .... I think even if you were running only 5-6psi your going to need 24 pound injectors. Im thinking 30 pounders to be safe
1995 Mustang GT
Why did that kit not require fuel injectors then? I just thought it was odd. What FMU ratio will i need for 8 psi?
1996 Saleen S351
The kits don't come with everything needed. You can go with a FMU but, for a few extra dollars you can get larger injectors. You will need a bigger fuel pum and I would install and fuel pressure regulator to be safe.
96 S351 #13 99 S351 #14 99 S351 #46 94 S351 #35 95 S351 #43 00 S281 #417 02 S281SC #117 |
1995 Mustang GT
I know i need a larger fuel pump. The kit said the a Fuel Control Unit tricks the stock 19lb injectors into thinking they are bigger so you don't have to change the injectors. The Paxton Novi 2000 says the same thing. I am pretty sure this can be done but i wanted to know if it was safe. I know the right way to do it. I just am looking for an alternative.
it doesnt trick the injectors, it loads a massive amount of pressure up behind them, which can (and has) caused failures in the injectors.
Including but not limited to... O-ring leakage, internal injector failure, eruption of the injector body, engine fires. Some things that can happen to your car. Fires, hydro-locked cylinders, melted pistons due to lack of fuel (failure dependent). In short, just buy the right injectors and get the car tuned.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
#7 | |
1995 Mustang GT
um yea... none...
get injectors and a fucking tune
1995 Mustang GT
I know I need injectors. I was told that along with the injectors you need a FMU to add fuel to them. If i buy a tweecer will I be able to tell my car how much fuel i need without an FMU?
95 opalfrost gt
Your still not getting it. Upgrade your fuel pump, injectors, MAF, ditch the FMU and have it tuned. If you would like to try your hand at tuning get a moates quaterhourse. From the sound of your mustang experience I would leave the tuning to a pro. good luck
For example...... Lets say you have 30 lb injectors but what you really need is 36 lb injectors, some times people will use the FMU that comes with the kit so they dont have to upgrade there injectors ( its the cheap way of doing it) but if you have 19lb injectors and if what your kit needs is 36lb then a FMU will not cut it. just buy 36lb-42lb injectors and get it tuned. you dont want the FMU. So with the correct size injectors a FMU is not needed. FMU are used when you dont have big enough injectors. do you understand now
I Poop Entirely Way Too Much
Blown 03 GT
Adding extra fuel buy increasing the pressure beyond what its suppose to be is just asking for trouble. It will work but it wont last!!
If you really wanna do it cheap search, you can find used injectors cheap. People are always upgrading them. I sold my 42s cheap when I went to 60s.
1995 Mustang GT
Guys! I KNOW YOU HAVE TO UPGRADE THE INJECTORS, FUEL PUMP, AND MAF!!!! I thought a fmu was used regardless of whether you upgraded the injectors or not. I am done with that now I understand. Thanks to ryanw. I do have a question about the tuners though. Can i buy a used quarterhorse or tweecer? Or are they married to the car they were first put on like other chips are?
you can go to a dyno shop and have them imput a tune into your computer. Or you can buy your own tuner like what you were talking about ^^ i have no clue if there married to the first car there used on. I dont think so
1995 Mustang GT
Well i figure if people are selling them used they probably aren't married but you never know. I think if I play with a tuner enough i will be able to tune it myself. I learn pretty fast. I just have to deal with all the people who think I can't do it first. I am still in High School if it makes more since about me not knowing much
let a shop tune your car. its going to be WAY over your head
1995 Mustang GT
Are you calling me stupid or something? I know I will probably have trouble with the thing at first but you shouldn't make assumptions about what people can do. I think if I mess around and do my research I will be able to tune it myself. How hard can it be? (Famous last words huh?)
1996 Saleen S351
Tuners for the 94-95 are not married to the cars. 99-up are only capable of that. He's not calling you stupid. He's simply saying you don't have the experience to do it correctly without damaging something. You need someone with experience period. Its not something you can just "try" and hope you get it right. You'll do more harm than good. Learning curve on something like that will cost more than its worth.
Have the tune perfect could gain you alot of hp. Or if its wrong could lose you hp and even damage some thing, a shop that tunes your car does more then just program it, they test the tune on a dyno and keep making tweeks to it until its damb near perfect. Just pay atention to what Addermk2 has to say he knows his shit
1995 Mustang GT
Thanks for all the help guys. I'll be back with more questions when I start my tuning
Threads Similar to: I have a fuel question
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| Air/Fuel question | jordon | 94-95 | 15 | April 30th, 2010 10:21 AM |
| Fuel Question | adrenaline=lifeline | 99-04 | 8 | February 8th, 2010 03:40 PM |
| Fuel Question | haywood11 | 5.0 Mustangs | 10 | January 15th, 2008 05:42 PM |
| Got a question about fuel | ocsailor86 | 96-98 | 3 | October 11th, 2007 11:10 PM |
