'94 GT Coupe
Let's make Mollie scream
It's time to give my 95 coupe some power.
302 5.0L motor, 5 speed manual, coupe. Only engine mods is cool air intake, aluminum radiator, slim fan and battery. Give me the top 20 engine mods: (Not the hood or taking a/c off. This is a daily driver, in the transformation of a beast.) |
i think you need to do more research.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
'94 GT Coupe
I know different mods that can be done, I've done the research and read multiple forums, I simply want people to list mods they've done.
I don't need anything visual or anything that's weight reduction. |
I won't give you 20 but these are the mods that are going to give you more power:
Heads, camshaft, intake manifold with matching throttle body, long tube headers, free-flow exhaust. The first mod I'd recommend is a 3.73 rear axle gear swap. Yours is currently a 3.08 so it would make a huge difference.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995 SVT Cobra
Seriously you do need to do more research. A lightweight hood doesn't have to be appearance enhancing.
Less weight can feel like more power. With everything you've read, you didn't see that everyone generally does the same modifications?
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
#6 | |
'94 GT Coupe
So far I have no cats or o2's, flowmaster exhaust, fiberglass hood |
#7 | |
95 opalfrost gt
No o2 sensors I think its time for me to leave
1991 Ford Mustang GT
Put your o2 sencors back on !!!!!!!!!!
wow, another retard that took out his oxygen sensors...
like I said... you need to do ALOT more research
'94 GT Coupe
sounded to me like it was a mods list, not a "to be fixed" list
dumbass
i would go thru the 94-95 section of this forum and read...it will tell you almost everything you want to know.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
#13 | |
![]() Not sure if you're directing the dumbass comment at the OP or at yourself but either way, it's totally unnecessary. Your Mr. Knowitall Smartypants comments are very annoying but then again, you've built a reputation on every forum you visit for being one anyway so congratulations.
#14 | |
Threads Similar to: Let's make Mollie scream
| well this doesnt scream pedo-ville | Ace417 | The Clubhouse | 28 | May 21st, 2010 03:20 PM |
| ... im gonna scream | Zatrekaz | The Clubhouse | 6 | December 17th, 2009 09:47 AM |
| Scream of 2.2 KB on my car | 95SC | Videos | 22 | August 16th, 2009 03:33 PM |
| Forward and Back. Scream it! | Dansby | Videos | 9 | June 5th, 2008 05:54 PM |
| These 2 girl's scream LOUD! | dmachine22 | The Clubhouse | 3 | April 1st, 2008 01:22 AM |
