1994 Mustang Gt
Bigger fuel injectors?
So I just ordered new cams, throttle body, heads, and intake. Should I upgrade my fuel injectors also? I was planning on using the stock ones and didn't want to spend the money in them really. But if I get them would I have to get a bigger fuel pump?
How many cams did you order? After all, you only need one.
![]() Any time you upgrade the H/C/I, you definitely need to upgrade the fuel pump (255lph) and the injectors (24lb).
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Last of the 302's
Road Racing Rookie
What heads? I'm still using 19's with my gt-40 heads and stock cam. Their at their limit but still work fine. 19's can support up to 300hp.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
#4 | |
1991 Ford Mustang GT
1996 Saleen S351
24lb inj would be a good upgrade. You will need a new mass air. You can find used ones on the corral or on craigslist. Like mentioned above, buy the fuel pump new. Ebay has them in the 100-120 range.
96 S351 #13 99 S351 #14 99 S351 #46 94 S351 #35 95 S351 #43 00 S281 #417 02 S281SC #117 |
Not quite. You can run 19lb injectors at stock fuel pressure up to 275hp (crank) but beyond that, you'll need to raise the fuel pressure. I have mine at 45psi with the stock injectors and I'm at 315-320hp (crank).
At the 340hp (crank) level, 19lb injectors are maxed out at 100% duty cycle and stock fuel pressure but that's with more efficient heads and a BSFC of 0.45. A set of 24lb injectors would drop the duty cycle to a safe 80% at the 340hp level.
1994 Mustang Gt
I have the GT40p heads. If I got the 24lb injectors wont i need to get a tune for that? I know that our cars are hard as hell to tune and I dont have a speed shop around locally to do a dyno tune, so know of anything to buy to tune it right?
they arent hard to tune at all.. Its just that your average mustang tuner is used to the caveman style a9l computer
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1994 Mustang Gt
So what would I need to get to tune it?
No, as long as you have an aftermarket MAF that's calibrated for 24lb injectors and run the stock fuel pressure, you should be fine. It's the cam swap that invariably sends the computer into a hissy fit but it's not an issue as long as the valve opening/closing events are reasonably close to stock.
Threads Similar to: Bigger fuel injectors?
| bigger fuel injectors | Ryguy33 | 99-04 | 6 | December 20th, 2009 04:33 AM |
| were to get bigger fuel injectors | mustanglouie | 2005 - 2010 | 4 | June 7th, 2008 05:33 PM |
| Bigger MAF, Bigger Injectors??? | oms4life | 5.0 Mustangs | 14 | August 28th, 2007 10:47 AM |
| will i need bigger injectors? | RyanGT | 99-04 | 9 | August 23rd, 2007 08:40 PM |
| fuel regulator vs bigger injectors | 1990CA50 | 5.0 Mustangs | 7 | January 7th, 2007 01:34 AM |
