oil pan gasket
Hey guys its me again lol. I've got a new problem. I thought my 94 was burning some oil, but after taking another look under the car my oil pan gasket is leaking. There is oil all around it. So how hard is this to change?
1991 Ford Mustang GT
are you sure its not your oil drain plug or front or rear main seal ?
No I don't even know where the front or rear main seal is. But its not comming from the drain plug I know that. Its up all around the gasket for the drain pan. Is where it looked like it was comming from
the front and rear main seal is the seal at each end of the crank shaft, but it can leak down and with wind blowing the oil around it can look like a oil pan leak
#5 | |
1995 SVT Cobra
You will most definitely need to raise the engine with either an engine hoist or a jack on the harmonic balancer with some wood. The gasket is a one piece so when the pan drops you'll have to get it around the oilpump and pickup tube. This is why the engine needs to be raised.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
So it sounds like a pain in the ass lol
Threads Similar to: oil pan gasket
| Oil pan gasket | 07 STROKER | 2005 - 2010 | 3 | May 22nd, 2009 02:11 AM |
| Which way does this gasket go?? | PowerShiftz02GT | 99-04 | 10 | December 21st, 2008 08:50 PM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| Which gasket do I need? | Roos85 | 99-04 | 3 | July 16th, 2008 10:34 PM |
| oil pan gasket? | lugthug713 | 94-95 | 9 | July 11th, 2007 02:32 PM |
