Whats some mods I can do?
I have a 94 vert. So far the following is done to it..its a 5 speed
steeda tri-ax short throw shifter 3.73 gears flowmaster 40 series underdrive pullies not sure if its cold air intake really, but its a spectre air filter on it |
1991 Ford Mustang GT
is the air filter in the engine bay.... If so its not a cold air intake.
Whats your budget ? that would help to figure out what mods to do next. If you have a big budget, id say cylinder heads (new or used) , or a used supercharger, with upgarded fuel pump (255lph),injectors (36-42lb),mass air (75mm or bigger)and TB (70-75mm)
like to keep the budget low for now. and yeah its still in the engine bay, so i guess its just a replacement filter? does a cold air intake add much to these cars?
You have a vert so your next mods should be weld-in full length subframe connectors (preferably rectangular tubing).
You can also remove the 25lb dead weight that's bolted to the passenger side front inner fender below the plastic liner.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995 Mustang GT vert
Hardly. Do you have the stock MAF setup? If so, then just pull the silencer out and put a new filter on. Virtually as effective as a CAI, and its free!!
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
Threads Similar to: Whats some mods I can do?
| heres my mods whats next? | joseph296 | 5.0 Mustangs | 21 | April 15th, 2010 10:57 PM |
| My Buddy Wants An 04 Whats Up With These Mods? | 1911A1 | 99-04 | 15 | November 10th, 2009 04:15 PM |
| Whats the best Mods for $1000? | 00Black2v | 99-04 | 120 | June 24th, 2008 04:35 PM |
| o1 gt mods whats next? | speegt | 99-04 | 25 | November 3rd, 2007 09:00 AM |
| Whats next on the list of mods | 06GTMustang89 | The Clubhouse | 10 | October 18th, 2007 08:33 PM |
