Newbie needs help w/94 GT Conv project buy
Old January 26th, 2011, 01:03 AM   #1
rowekmr is on a distinguished road
Hello
I found a 94 GT Convertible that is immaculate in and out. It has the Saleen front adn rear valence and some aftermarket side skirts with aftermarket rims. It is dark green exterior with black leather interior (seats from a 2004). He says the auto trans is bad and it has 88K. It has flowmasters, HID lights, MSD 6AL box and coil/cap/rotor. It starts up quick and sounds good (don't know if H pipe installed). He was asking 3.8K and I offered 2.3K and he agreed. He also had new in box Perfomer Aluminum heads, Edelbrock upper and lower and elbow, and a Comp Cams 280 kit (timing wheels, chain, springs, retainers, etc,) that he wanted 1.6K and I offered 1.1K he countered 1.2K.
What do you think of the value of the car and are the parts something I could use to make this car stronger yet streetable?
He doesn't have headers and its stock gear but when I looked on the Comp Cam site they recommend 2500 stall, headers, bigger mass air and bigger TB for this cam. What could I look to make with this installed with mass air, tb and headers? Is a higher stall really necessary? Are these engines tuned with the handhelds (SCT) or do they need chips burned. I haven't had a Mustang since my 88 GT Vert twenty years ago!
Thanks
Joe
Old January 26th, 2011, 02:06 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
Pics would help. At $2300 i would do it, seems like a good deal. As for the price of the parts, if there brand new then you got to figure is another $100 worth it to you. If you were to order these parts new it would cost you more then that. If there used parts it still not that bad of a price. You want all your parts to match each other to get full power out of them, So if they call for a different stall to be with in the same RPM range as the cam then you might wanna look into it
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 26th, 2011, 04:44 PM   #3
95StangMX's Avatar
95 Mustang GT
I would take the money you would spend on his top end kit and put it towards a set of trick flow heads and intakes, and a custom grind cam, or if you don't want to go the custom cam route, just buy the whold Trick Flow top end kit.
As far as your transmission goes give silverfoxbody a PM his name is Dan and ask him to build you a valve body that will shift, and get with Alan @ DirtyDog Performance (Powered by CubeCart) about a stall
One of the first things you need to do is get you a set of subframe connectors on her also. Get some pics up here when you get a chance and congrats on the find, sounds like you got a great deal.
Old January 26th, 2011, 04:58 PM   #4
I took some pics but don't know how to upload them. This guy really took care of it because it was literally spotless. If someone can tell me how to upload I will.
I notice a lot of cars in MM&F use Trick Flow or AFS heads. Are those the best street heads? I looked on Mustang Restoration and they had many heads for the 5.0 so don't know which one is best bang for the buck. I have already looked online for equal length headers do you guys recommend the H pipe or X pipe to go with them?
For trans I found a few local less than 80K for 250-700 asking price and found a Monster Transmission stage 2 AODE for sale with 2K stall for 650 with 1,000 miles on it but I will have to ship it. I want to get it running first then work on upgrading it.
Old January 26th, 2011, 10:15 PM   #5
ryanw's Avatar
up load the picks to photobucket.com then copy and paste the code
255 fuel pump,
3:27 gears
Old January 28th, 2011, 06:22 AM   #6
Ok I will try to post the ok pics I took at his house:
http://i817.photobucket.com/albums/z...gGTConv002.jpg
http://i817.photobucket.com/albums/z...gGTConv028.jpg
Old January 28th, 2011, 07:06 AM   #7
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
uhg.... body kit
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old January 28th, 2011, 01:19 PM   #8
When I picked up the car he lowered the prices for the parts to 1K but I found out the cam kit is actually a Comp Cam 284 and on their website they call it a supercharger cam, the heads are Edelbrock Performer aluminum with 60 cc combustion chambers and 170 cc runners. The manifold is their Performer manifold (not RPM). Not sure if this is a good combination. I thought about selling that cam (list 500) for a milder cam or as someone posted above getting Trick Flow heads (which ones) and intake and cam but don't know the cost of those. I found a stage II trans and 2K stall conv in NJ with 1,000 miles on it for 650 and might get that instead of a take out (stock) trans.
Old January 28th, 2011, 01:21 PM   #9
Can you tell which body kit it is? I don't know I had a communication barrier with the seller (needed a translator) so I wasn't able to learn the finer points of it.
Originally Posted by AdderMk2 View Post
uhg.... body kit
Old January 28th, 2011, 01:38 PM   #10
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
its not saleen
Threads Similar to: Newbie needs help w/94 GT Conv project buy
Project Newbie under construction 5.0 Mustangs 69 November 5th, 2009 06:24 PM
project newbie under construction New Members Introductions 17 November 2nd, 2009 03:21 PM
88 lx conv firefly1241 5.0 Mustangs 2 April 26th, 2008 01:02 PM
newbie needs conv SemperFi Classic Mustangs 14 January 9th, 2007 09:30 PM
