5.0 and only 215 hp.....what's up with that?
Old January 26th, 2011, 08:40 PM   #1
rkboz is on a distinguished road
yeah I know, you guys already know that but my last mustang was a 01 cobra and I got spoiled but come on....215hp that's lame. I didn't buy the car to drag race but I think it has a lot of hp that needs to be woke up.
I think I'll buy a used 5.0 from the auto wreaking yard and make a fun project with the boys and I. They've never built a motor before, it should be fun. I was just wondering what heads would be a good bang for the buck? I would think a good low to mid range cam would be the way to go. I like a low end torqey motor. Any advice guys?
Old January 26th, 2011, 09:43 PM   #2
roast&toastEM's Avatar
1994 Mustang GT
roast&toastEM is on a distinguished road
gt40 heads and intake, u can find them everywhere and great bang for the buck.
1994 Mustang 5.0
Old January 26th, 2011, 09:56 PM   #3
gt40 heads eh? Is that what came on the cobra 5.0
Old January 26th, 2011, 10:21 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
they came on explorers, also grab the gt40 intake thats also on the explorer. I forget what years though, some one else will have to chime in on that, or just google it
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 27th, 2011, 01:26 AM   #5
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Thats a GT40-P head I thought on the explorer...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 27th, 2011, 01:35 AM   #6
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Yes. But later model explorers with the same motor had gt40 intakes as well.
I'm pretty sure the low HP has to do with emission laws, etc. at the time. You can get a lot of power off of simple bolt ons. Underdrive pulleys, intake, exhaust, CAI. Hell, even just removing the intake silencer gives a few more HP.
Lets not forget that the chevy 5.0 (305) turnes out less than 185~hp in stock form.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old January 27th, 2011, 10:41 AM   #7
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Oh it most certainly does. You can get it up to 300 crank HP (260rwhp) with just simple bolt-ons and GT40 heads/intake. The GT40P heads from the '97.5+ Explorer would be even better and you can find them for ~$300 in ebay.
With bolt-ons and a Trick Flow top end kit, you can easily crack 360 crank HP (310rwhp).
CompCams XE264HR-14.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old January 27th, 2011, 11:24 AM   #8
95StangMX's Avatar
95 Mustang GT
If you are going to buy a used 5.0 from the salvage yard, just go ahead and pick one up out of a late 90's explorer, then you will have the gt40P heads, intakes, and all you will need to do is change the cam.
Otherwise if you really want some power you can go the route I went and go with a 347 stroker, if you really want to churn out some ponies. FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines builds some nice short blocks and longblocks, You could get a 347 rotating assembly from Jim @ strokers and then top it with the trick flow top end, ditch the cam, and get a custom grind. All depends on how fast and how much $$$$
Old January 27th, 2011, 11:17 PM   #9
All good stuff to know thanks everyone.
