1995 5.0 GT vert.
Overheating help please!!
Hey guys, new to the forum but I have a modified 95 vert 5.0
Had new head gasket and internal gaskets felpro redone.. RPM heads, U&L intake.. new radiator fan.. radiator hose.. and radiator cap installed. Car has been stored but recently took it out a few times and this is what I'm experiencing... let the car warm up get to about 180 temp so coolant enters the block, start to drive it and all of a sudden the temp gauge rockets up to about 3/4 and when it does this the heat in the car goes cold as if the A/C was on... popped the hood and the upper radiator hose was cold still..so I killed the car waited about 10 minutes started it up and the heat was normal and Upper hose was warm coolant was flowing and car ran normal for the duration... Just today i started it up and it did the same thing once the temp hit about 180.. so I killed the car again waited about 10 minutes or so.. was still skyrocketing up to 3/4 and heat was still ice cold when i drove it.. popped the hood and now there is a slight drip of coolant coming from the radiator cap.. is it not holding the pressure?? HELP much appreciated was told it could be a sending unit went bad? or bad cap? |
1995 Mustang GT vert
Sounds like the water pump/thermostat is going out. Does the fan kick on when it starts to get hot?
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
1995 5.0 GT vert.
Well my mechanic wired up a relay so that the fan kicks on as soon as i start my car and doesnt shut off until i turn the car off.. this is only temporary until i can get a new module for the fan to kick on at the right temp, but have had no problems since summer when he did it.. until now.
1995 5.0 GT vert.
Could I have an airpocket somewhere ?
95 gt vert, 4.10 rearend, edelbrock rpm heads, edelbrock rpm U&L intake,50 dry shot nos, 70mm TB, 32lb injectors, E303 Cam,Comp 1.6 rockers, Comp Pushrods, BBK Cold air, 255lph walbro fuel pump, flowmaster side exhaust |
#5 | |
You may have an air pocket but I don't think its the root of the problem. Just run the A/C for a few minutes then switch it to heat for a few minutes. This will get rid of the air pocket effect. If the coolant drops significantly, then you had an air pocket. If it doesn't and still overheats, I'm still betting its the water pump and/or thermostat.
1995 5.0 GT vert.
alright thanks john preciate the input ill check it tomorrow and post the results
1996 Saleen S351
Did this start right after you had head gaskets installed. If it did then the head gaskets were installed wrong. That will cause the same issue.
96 S351 #13 99 S351 #14 99 S351 #46 94 S351 #35 95 S351 #43 00 S281 #417 02 S281SC #117 |
1996 Saleen S351
It definetely could be an air pocket. Did this start right after you had head gaskets installed. If it did then the head gaskets were installed wrong. That will cause the same issue.
It could be an air pocket but I think it is more likely to be a water pump. BTW most of the time if a thermostat goes out it usually sticks open and doesn't overheat.
#10 | |
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
im sorry... i really must know.
what the hell is with the ricer spoiler?
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1995 5.0 GT vert.
hahaha the ricer spoiler was on there when i bought the car and since i put all my money at the moment into rebuilding the engine... thats a concern that will be fixed down the road lol
and to s35s post, no it didnt start happening right after head gaskets were installed probably about 6 months later out of no where it happened... but so far what i have done since its to cold and not garaged just underneath a car port, is just burped the system and tried swapping the ac to heat a few times as john said that may help... so next step im gonna take is to replace the water pump, new thermo, and radiator cap and flush my system... should fix the problem appreciate everybody that has replied with info. THANK YOU.
Threads Similar to: Overheating help please!!
| 98 GT overheating | tvllgeorge | 96-98 | 7 | December 9th, 2010 10:17 PM |
| overheating | rob madison | 4V / SVT | 1 | November 5th, 2010 04:25 PM |
| Overheating | 2006GTARPD3 | 2005 - 2010 | 52 | June 5th, 2010 11:57 AM |
| overheating | 98Cobra_sleeper | 4V / SVT | 6 | May 6th, 2010 10:11 PM |
| Overheating | silver99gt | 99-04 | 16 | June 2nd, 2008 11:09 PM |
