C Mor Semen
1995 Mustang GT
Not fast enough
question!
How in the world does my harmonic balancer break?!
![]() MAC CAI, SLP LM1's, Steeda short throw shifter, UPR O/R X Pipe, 3:73 gears, and more to come. |
1995 Mustang GT vert
If you hit something going down the road and it smacks it at 60mph. Also, its usually the seal or the bolt holding the balancer on that goes bad.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
C Mor Semen
1995 Mustang GT
Not fast enough
hrmm. weird. i was just driving the other day and the engine just went bezerk. Me and my dad had no clue to what it was, seeing as though EVERYTHING but the shaking of the engine was fine.
Yea. Its really hard to actually "break" a harmonic balancer. It gets bent in most cases.
C Mor Semen
1995 Mustang GT
Not fast enough
Mines shattered
how it happened
is it shattered? or did the rubber on it break, ive seen it several times where the rubber on it let go and the pulley part separated causing the belt to jump off.
315's Crew Black and White Crew Crew Member #2
C Mor Semen
1995 Mustang GT
Not fast enough
It's shattered I believe.
can you post some pictures? id love to see the carnage and get an idea of what may have actually happened
C Mor Semen
1995 Mustang GT
Not fast enough
I will tomorrow. That's when were fixing it.
the rubber goes bad, that holds the outer ring n place. if yours came apart, then the ring hit something b/c it was wobbling... i can see the possibility of it breaking
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
C Mor Semen
1995 Mustang GT
Not fast enough
The back of it broke. I'm having trouble getting the bolt off of it. i dont have a pulley remover. i heard you dont need one though?
but the new one i got doesnt even look like the one that broke.
pics would be great bro
C Mor Semen
1995 Mustang GT
Not fast enough
I will, my iphone doesnt take good pictures in dark scenery though.
#14 | |
Did you get an OEM replacement? 28oz? 50oz?
C Mor Semen
1995 Mustang GT
Not fast enough
![]() ![]() those are the best i could get. Edit: the 50oz? its pretty heavy.
I can't even tell where its "broken"
.I got a 50oz on my car when mine went out. I don't really know the difference between them besides weight. Can anyone shine some light on my ignorance?
it looks like the rubber on it went out and cause the pulled to come off.
ok, so it isnt shattered, like you posted. It merely failed in the most normal of fashions... the rubber ring delaminated, and the outer section came apart... We have come to know this is the NORMAL failure of this part. unbolt the pulley, its held on by 4 bolts. then start working on the crank bolt. its 15/16"
C Mor Semen
1995 Mustang GT
Not fast enough
They told me it shattered... Just telling you when they told me.
We got it off but apparently this had happened before, seeing as though the threading is fucked up. Does anyone know the size of the bolt so I know what size of tap and die kit to buy?
Everything I have found are between 2 inches and 2.05 inches long. I'm sure the 2 inch will work fine.
The thread size is 5/8" -18. (18 is the thread count size. VERY important.) I had to put a new bolt on my old camaro for its harmonic balancer just recently. Just go to Home Depot and go to the bolt isle. They have a whole WALL of different sizes. Just look for: 2" x 5/8" - 18
Threads Similar to: question!
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| cam with nitrous question, frpp manifold intake question | slater | 2005 - 2010 | 57 | November 14th, 2010 05:40 PM |
| Exhaust question and tuner question.....dont laugh lol | Drick | 99-04 | 19 | September 24th, 2009 03:42 PM |
| Exhaust question + supercharger (warranty) question | r00st | 2005 - 2010 | 2 | January 31st, 2008 11:07 AM |
| Muffler question (visual aspect) + Emblem question | warrior86 | Visual | 5 | November 20th, 2007 09:55 PM |
