sn95GT
Motor Swap
Want everyone's thoughts on this. I have a couple of F150s and they both have. 4.9l six's. looking for solid axle swaps I came across two turbocharged projects. Both used early Chevy v8 diesel turbos with no intercooling.One had the turbine downstream of where the cats would have been. The other had the turbine on one of the exhaust manifolds with y from the other manifold also feeding the turbine. This later setup used a megaquirt and 24lb injectors for fuel supply on the stock ECM. He dynoed 300whp and 525wtrq. One one my 4.9l's is built with forged parts fastened with ARP hardware. To negate building a windsor block to handle the cylinder pressure, I am contemplating swapping my six into my mustang and fabricating a propper turbo setup to match the motor. Based on the two Chevy turbo based projects, I was thinking 400whp and 600wtrq would be easily achievable. Your thoughts. If an SN95 won't fit the block the foxes had a six in them.
1995 Mustang GT vert
If it only made 300hp at 525trq, it sounds like there is a lot of HP thats getting lost somewhere.
You are talking about the inline-6 right? Not sure exactly how it would fit in a SN95, but it would be badass!! Inline 6s can be made into monsters.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
#3 | |
95 opalfrost gt
1992 Mustang LX
13.0 @ 105
^^^ What he said...Pick up an aftermarket block, decent rotating assembly, and throw tons of boost at it. That'll be a better option..
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
Forget about trying to fit a big inline six under the SN95 hood. It's too long to fit from front to back and too tall to fit under the hood. Even if it did fit, you'd have more weight in front of the wheels which would increase understeer and diving under braking.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Threads Similar to: Motor Swap
| motor swap | tutman900 | 5.0 Mustangs | 12 | December 28th, 2009 10:41 PM |
| motor swap | fast5liter | 5.0 Mustangs | 6 | October 26th, 2008 10:44 AM |
| motor swap | izze01 | 5.0 Mustangs | 5 | August 13th, 2008 04:21 PM |
| Motor Swap From 95 GT.. Will It Fit? | 81 Merc. Capri | 94-95 | 14 | March 5th, 2007 10:11 AM |
| Motor Swap | 808pony96792 | 5.0 Mustangs | 3 | September 15th, 2006 03:36 PM |
