sct tuning software need help
Old January 29th, 2011, 05:29 PM   #1
mutlyi4's Avatar
95 mustang gt
mutlyi4 is on a distinguished road
does anyone know how to use the pro-racer software from sct and if so how would i go about tuning my 95 gt it has
ford racing #30 injectors
edlebrock e-street heads 1.9 intake 1.6 exhaust valves
90mm lighting maf
gt40 intake
com cams cam .544 .555 lift 216 224 dur (cam number 35-514-8)
1.6 roller rockers
timing set at 14 degrees
and an auto trans
any help would be great
Old January 29th, 2011, 11:43 PM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
you need to set your timing back to 10° for one. as the program will assume that you have it there
you dont need 30# injectors for that setup
you need the maf transfer for that LMAF
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old January 30th, 2011, 01:59 AM   #3
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Agreed.
Unless you are planning on going supercharged or turbo in the future, you aren't going to see very big gains from those injectors or that huge MAF. Your car is just going to run really rich if anything. I would step up to 1.7 rockers and run 24lb injectors to make a real world difference in horsepower.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old January 30th, 2011, 10:39 AM   #4
Trick Tuners's Avatar
KB'd GT
You should get a base tune from the dealer that you buy from. Start reading books on tuning too!
Good Books on Engine operation and EFI tuning - Trick Tuners Forums
Threads Similar to: sct tuning software need help
Best tuning software? scp616 99-04 7 May 15th, 2010 06:11 PM
Just ordered my tuning software. 3sportbob 99-04 18 April 18th, 2010 12:21 AM
Custom Tuning software, know of any stangman92 99-04 8 November 20th, 2009 10:10 AM
Tuning Software Dracer35 99-04 9 October 26th, 2008 07:12 PM
anybody using sniper tuning software dumps 2005 - 2010 2 July 10th, 2007 10:30 AM
