cam?
what the highest lift cam i can put in 351w before valve to piston touch. i have tri state heads with .600" springs. motor has e303 cam when purchased but i dont care for it, this is just a weekend car.
1969 Mustang Mach 1
6.824@101.61
There is no way to answer that. There are a billion factors. The ONLY way to know, is to put the cam in and check it. And FWIW, how long the valve stays open is more crucial than how far it opens when it comes to P to V clearance.
And I would never use springs that come on a head with an aftermarket cam, just because the head manufacturer says they're good to XXX amount of lift. Always check with the cam manufacturer. Proper valve springs are crucial to your engine.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
#3 | |
1995 Mustang GT
Peace of mind is worth the time and money. Incredibly expensive should the piston kiss the valves.
1995 SVT Cobra
You also may not know how long those springs have been on the heads; i.e. how "used" they are. I'm surprised you weren't offered a spring set or at least recommended a spring set for the cam you're looking at for your engine.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
#7 | |
the motor was put together 4 month ago. i've had it for 2 weeks want to change a few things. heads are 4 month old. if i get the comp cam kit the spring are 987-16. ill have to look the spec up on mine or call comp cam. i'm just wanting to know if i was the get this cam or even the cam kit would it fit without my valves hitting. or what the highest lift to be safe for the 351w it a 95 roller motor.. |
#8 | |
89 GT
worst case, you have to notch the pistons. It's actually easier than a lot of people think it is. And fuck all that good to .xxx lift stuff for springs. You want the right installed height, and to know what the pressure the cam calls for at the seat and open, and you want to get optimal coil bind distances for more stability at higher RPMs, generally between .100 and .060 away from bind. |
#9 | |
