Sputtering?
Old February 6th, 2011, 07:10 PM   #1
96StAnG5.0's Avatar
1996 Mustang 5.0
14.0
96StAnG5.0 is on a distinguished road
Exclamation
Sputtering?
When it sits.the car sputters a little here and then and when I floor it it feels like a beast BUT when Im driving its like a lack of fuel or something.I have FULL MSD Ignition which its MSD wires,MSD distru not just the cap/rotor,NGK TR6's,MSD Blaster 2 coil,and the MSD 6AL box.So if Im getting spark,I dont know what else to think...
I was reading in another thread that it could be the MAF but is there something else that controls the ignition or its timing or something/Any help would be very much appriciated...
A Ricer is a stupid young idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground-LMFAO
Old February 6th, 2011, 07:15 PM   #2
Better than Drugs!
mayosailor27's Avatar
97 Cobra makin' women wet
Decent @ A fast one
mayosailor27 will become famous soon enoughmayosailor27 will become famous soon enough
check codes, even if there is no cel, check them. for a long time i didnt have a cel, turned out to be o2 sensors causing a shitty idle, feeling like lack of fuel cruising, wot was good but once in a while it would stall out at lights, little surges here and there. I replaced all kinds of things and finally checked the codes lol. Learned a lesson anyway Just check it out.
96 GT-sold
98 GT-05 katrina victim-parted
90 GT-traded
98 GT-traded
98 GT-parted
94 GT/Cobra-sold
95 Cobra Saleened-sold
97 Cobra-knock -sold
99 GT-knock-sold
97 Cobra-sold
96 Cobra-nothing wrong but stock!
MM Cobra member 969
Old February 6th, 2011, 07:37 PM   #3
96StAnG5.0's Avatar
1996 Mustang 5.0
14.0
Well I have the CEL and I come across is the EGR low circuit which I dont have one and secondary air bypass which is the smog deleate,I have NO emissions at all so those are the only codes that come up.Like it sputters bad I cant figure it out,it has to do with either air or fuel which the next thing im looking to get is a adj fuel pressure regulator.I also have a Walbro if that helps if anything lol
Old February 6th, 2011, 07:52 PM   #4
1995 SVT Cobra
Cobraman1024 is on a distinguished road
Robert?
The distributor on the 94/95 5.0L engines has a Profile Ignition Pickup sensor in it which by design senses when the rotor is pointed at cylinder #1 and tells the computer when to fire the fuel injectors. This sensor is known to fail gradually so that you'll have issues that point to a problem with the fuel system.
The EGR system usually will not cause major issues with this engine.
Fuel pump? yes its a possibility. First though, when was the last time you changed out your fuel filter?
MAF is also a possibility.
Does this problem get worse or get better as the engine is warmed up to operating temperature?
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old February 7th, 2011, 09:20 PM   #5
96StAnG5.0's Avatar
1996 Mustang 5.0
14.0
Yea Robert and watsup man!!!! LOL YEa bro I got a NEW msd distr and coil so its nothing Ignition wise...Fuel pump is a walbro 255 so thats brand new too bro and when the car is warm its alot better but at start up I go down the street it just sputters like crazy like as if I accelerate while it sputters it just sounds like its missing...But when its warm it runs fine I have no clue wats going on im not gettin any miss firing codes or anything...
Old February 7th, 2011, 09:29 PM   #6
Better than Drugs!
Decent @ A fast one
MSD stuff right? do a search on the MSD ignition stuff. Named "my spark disappeared", "my spark died" for a reason anyway-- What's your timing set at?
96 GT-sold
90 GT-traded
98 GT-traded
98 GT-parted
94 GT/Cobra-sold
99 GT-knock-sold
97 Cobra-sold
MM Cobra member 969
Threads Similar to: Sputtering?
sputtering under WOT burnout5.0 4V / SVT 9 October 26th, 2010 04:52 PM
car sputtering! s197stallion 2005 - 2010 7 June 5th, 2010 09:52 PM
sputtering.. Chris951 5.0 Mustangs 12 November 1st, 2009 09:33 PM
Sputtering 03 gt BDaily 99-04 11 March 16th, 2009 02:16 AM
GT Sputtering? outlawedstang 99-04 12 December 13th, 2007 10:44 PM
