System hook up
Old February 6th, 2011, 11:31 PM   #1
Foxmoto28's Avatar
'94 GT Coupe
Foxmoto28 is on a distinguished road
System hook up
I had the mach 460 system in the '94 and after everything went to hell I took the rear deck out and hooked up speakers all around. I'm curious now if I need to hook up the amp remote wire to the factory harness or can I just run it strictly to an aftermarket amp?
I don't see why hooking the amp wire to the harness would help at all if there isn't anything to be powered with the harness.
Old February 7th, 2011, 01:29 AM   #2
Foxmoto28's Avatar
'94 GT Coupe
I'm also hooking up a bypass for my Pioneer AVH-p4100DVD
Any comments on this?
Old February 7th, 2011, 03:50 PM   #3
95project is on a distinguished road
not sure i understand your question...the remote wire needs to be hooked to a switched source so that the amp is not always on...amp in the receiver or the amp powering the speakers...works the same on both.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Threads Similar to: System hook up
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 14 May 1st, 2011 02:17 PM
Can someone hook me up with a sig thanks SonicGT Chopshop 37 August 31st, 2010 08:32 PM
Another Cop Let Off The Hook... joka187 The Clubhouse 1 December 8th, 2007 03:56 AM
will this hook up to my 96 blown96stang V6 Mustangs 16 October 7th, 2007 10:24 PM
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 11 June 18th, 2007 07:56 PM
