Manual Transmission Fluid - Forums at Modded Mustangs
post #1 of 36 Old March 13th, 2011, 01:00 PM Thread Starter
So yesterday I changed my T5's fluid. I wanted to go to what i thought is best, and got Carquest Dex VI synthetic. Now i'm reading and everyone is saying dex/merc III is what should be in there, or a rebuild would be coming soon. It shifted through all the gears just fine and got me home (an hour on the highway) just fine. Do you guys think it'll be okay of do I need to drain/fill again with dex/merc III this time?
Any advice is appreciated. Thanks!
ATP94GT is offline
post #2 of 36 Old March 13th, 2011, 02:29 PM
Send a message via MSN to BikerSk8rKid Send a message via Yahoo to BikerSk8rKid
I wish I could help ya, but I'm not to sure. I use Royal Purple for almost all my fluids.
BikerSk8rKid is offline
post #3 of 36 Old March 13th, 2011, 04:43 PM
Tdymorris's Avatar
I run royal purple engine oil, ATF, and gear oil, I wouldnt go with anything else
Tdymorris is offline
post #4 of 36 Old March 13th, 2011, 04:45 PM
FastStang91Lx's Avatar
GM syncromesh is one of the best. I use that in the Amsoil version.
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #5 of 36 Old March 13th, 2011, 04:58 PM Thread Starter
Hey thanks for the input but i was told only to use ATF because I was going to get royal sychromax but the store manager (an avid racer and sounded like he really knew what he was talking about) said that since its the factory T5 and it calls for ATF means i cant use anything else because the tolerances are made for ATF (whereas synchromesh or RP is too thick). I wanted a synthetic so I got dexVI. It seems ok now but i read not to use sythetic and to stick with dex/merIII? Also I believe the tranny may be a tad noisier but i could just be paranoid.
ATP94GT is offline
post #6 of 36 Old March 13th, 2011, 05:10 PM
I haven't had any problems yet using Royal Purple for my Tranny.
I got mine because of the reviews from people on AM and the info on it.
http://www.americanmuscle.com/royal-...ion-fluid.html
post #7 of 36 Old March 13th, 2011, 05:45 PM
I've been running Motorcraft synthetic dex/merc and had no issues. Lubricating oil is used based on the shear the oil needs to provide, and the viscosity needed at the operating temp the oil lives at. Various lubricating oils will meet those requirements. Also there can be issues with certain petroleums eating seals.
blueovalbleeder is offline
post #8 of 36 Old March 13th, 2011, 07:17 PM
12 years ago, I had a guy at an autoparts store tell me that the trans (according to his computer) was supposed to use 80/90. Yeah, that trans didn't last. So just because he was behind the counter doesn't mean he knows what he's talking about. If you are that worried about it, go down to your local Ford dealership and ask them. But I've never heard of synthetic NOT being good for something. It has smaller molecule, which is why an existing leak will usually leak more, and there is no issue with lubricating in the smallest area. If the oil is too thick, that's where your issue comes from.
post #9 of 36 Old March 13th, 2011, 07:39 PM
Powered by LSx tears
69fastback's Avatar
Another thing about synthetics....
Older style transmissions rely on a certain amount friction for the blocker rings to do their jobs, and in some cases, a synthetic oil doesn't allow that to happen. It seems to be hit and miss in them working or not. I run 80-90 in my toploader, but that's what it calls for.
I tell the truth. Deal with it.
69fastback is offline
post #10 of 36 Old March 13th, 2011, 07:53 PM
Older style transmissions rely on a certain amount friction for the blocker rings to do their jobs, and in some cases, a synthetic oil doesn't allow that to happen. It seems to be hit and miss in them working or not. I run 80-90 in my toploader, but that's why it calls for.
That is true too....
post #11 of 36 Old March 13th, 2011, 08:13 PM
I just realized that my Tranny Fluid is leaking very small amounts through the drive line. Which just started happening recently. I've been using Royal Purple since 2009 I believe.
Is that because of the Fluid I'm using or because I have 110k+ miles and it's probably due for new seals?
Early 2010 I did my clutch for my first time, I could have messed it up then. :/ lol
post #12 of 36 Old March 13th, 2011, 08:36 PM
Where is the leak coming from? front or back of trans? And I'd say age, and the molecule thing I posted earlier.
post #13 of 36 Old March 13th, 2011, 08:44 PM Thread Starter
Ok I get what you're saying, but do you think since the synthetic has smaller molecules that it would been a little noisier than the thicker factory fluid which could, in a sense, dampen the sound? And does the end number (dexIII, dexVI) just mean its a newer generation in the fluid with better properties or is it a specific grade like engine oil is? I'm reading people are saying its suppose to use 3 and not six, whereas this is also a 3 synthetic so did i mess up grabbing the wrong number?
Thanx
Aaron
ATP94GT is offline
post #14 of 36 Old March 13th, 2011, 08:45 PM
It's coming from the back, right where the cuping is for the drive line. It's barely leaking. I'm hopping it's the age, because I like Royal Purple.
post #15 of 36 Old March 13th, 2011, 08:46 PM
Thanx
Aaron
I'm curious to what noise your hearing.
post #16 of 36 Old March 13th, 2011, 08:59 PM
Thanx
Aaron
Different viscosity
As in where the driveshaft goes in? That just a tailshaft seal that you can easily replace. I have one to do on my wife's car too.
post #17 of 36 Old March 13th, 2011, 09:16 PM
So since it's a different viscosity, that would cause his to make noise?
My mechanic said the first seal will be easy, but the other seal or bearing might be wrecked?
I know I have to pull the driveshaft out, but do I have to drain the oil?
post #18 of 36 Old March 13th, 2011, 09:38 PM Thread Starter
Its not that theres a specific noise, its just the normal operation sounds are easier to notice. Could just be my motor though... haha i dont really know of a specific noise, it just sounds louder.
ATP94GT is offline
post #19 of 36 Old March 13th, 2011, 09:53 PM
Where does it sound like it's coming from?
post #20 of 36 Old March 13th, 2011, 10:04 PM Thread Starter
Well when I first got the car, it had a high pitched whine. the other night i pulled up to my friend and he was like "it sounds like that things supercharged!" But thats nothing new. I'll diagnose that later. After draining and filling the tranny it just seams like theres more little noises (one possibly being a tiny exhaust leak but haven't checked it out yet). And like i said it just feels like the tranny operation is a little noisier now but i could just be paranoid.
ATP94GT is offline
Human Verification
