Pypes headers - Forums at Modded Mustangs
post #1 of 9 Old March 20th, 2011, 11:07 PM Thread Starter
jordon's Avatar
Pypes headers
I'm looking at switching out my current headers for something different and in better condition. Mine have several years of wear on them now and are showing it. Anyone have any experience with the shorty headers by Pypes? Any info in regard to installation, fitment, issues, likes, dislikes, performance would be greatly appreciated! Anyone have any opinions on the Pypes brand in general? Thanks
Aluminum heads, TF upper/lower, bbk tb
c&l intake w/Pro*M Racing MAF, shorty headers
24# injectors, off-road H, custom catback
H&R springs, 3.73's
short throw.....still slow.
jordon is offline
post #2 of 9 Old March 20th, 2011, 11:54 PM
i have the pypes catback and i love the sound, but the guy who installed my catback said it was a bitch to get it to tuck under, but he got it
2011 Mustang GT:
SW Longtubes, O/R X pipe, Outlaws
Lund tune
Eibach lowering springs
mustangmaniac95 is offline
post #3 of 9 Old March 21st, 2011, 11:39 AM
tranram's Avatar
yes sir these cars are VERY TIGHT LOL! thats how we like it. really thow make sure you see if that brand has problems with hitting the steering,shaft going to the rack, the ones i found,cheap,easy to put on and dont hit. was flowtech 120 bucks
performer heads 2.02 values,prw stainless roller rockers,hardend push rods,
trickflow upper,lower.lunati cam
24lb injectors,75mm tb,
shorty's 2.5 pipe,h pipe, into 1 chamber 40 series flowmasters, aode,410s
18inch GT500 wheels,saleen body kit
tranram is offline
post #4 of 9 Old March 21st, 2011, 03:02 PM Thread Starter
jordon's Avatar
Flowtech huh? I guess I've never looked into that brand. When you say easy to put on, what did that entail? I know headers are a bitch in general, but I'm mostly concerned about the rubbing issue and the fitment to my midpipe. I'm not going to go with BBK again, so they are out. I was just trying to keep everything from AmericanMuscle. Free shipping is huge!
H&R springs, 3.73's
jordon is offline
post #5 of 9 Old March 21st, 2011, 09:07 PM
tranram's Avatar
it took me a hour and half, but i have 3 little boys swipn tools so they can be fast to,LOL, but its very easy .they are block hugers, thats the key for our bodystyle!
the only rubbing would be on the stering shaft like i said before,and there is still plinty of room to change the plugs thats HUGE.. hope it helps
tranram is offline
post #6 of 9 Old March 21st, 2011, 11:30 PM Thread Starter
jordon's Avatar
yeah its helpful. Thanks. I'm finding them for about $180 though from Summitt to Jegs. How are they performance wise? I've read that they are prone to leaks and what not. Any issue with that for you?
H&R springs, 3.73's
jordon is offline
post #7 of 9 Old March 22nd, 2011, 05:11 AM
fogged306's Avatar
They are prone to leaks. They have slip joints that leak almost instantly and the flanges are too big on some heads and don't fit well. If you grind the flanges to fit and weld up the slip joints they're not a bad deal though. The collector is kinda crappy and could use some clean up too where the primaries are welded in, but a die grinder and a straight metal carbide tip can do that pretty well. Nice thing about them is that they have a 3" collector with a 3 bolt flange. I would buy them over any BBK junk anyday as long as you put a little time into them to fix them up a bit.
fogged306 is offline
post #8 of 9 Old March 22nd, 2011, 10:46 AM
tranram's Avatar
you are correct on the old stuff, but that was a hit and miss, there new line has a better fit to many heads, i have had mine on for over a year "stock 5.0" and keep them with the build,the only thing i did was had them glass bedded and hit them with high temp header paint.The trick is to order a second set of gaskets, or get the thick costly ones they offer. personaly i used the set that came with them and a same,second set at the same time NO PROBLEMS,FYI i also have them on my 2001 tahoe, and they are the old series never a issue over 3yrs old.
tranram is offline
post #9 of 9 Old March 22nd, 2011, 02:12 PM
fogged306's Avatar
Mine are from last summer. They're the summit headers, which are the same exact thing, both are made at the same place. I would grind the flanges down before I doubled up on gaskets or used a thick one. It's just the tops over each primary tube that hit on my TF heads, but it wasn't a big deal to to. Might also be different on the SN cars, but I'm sure you're still going to have to do some work to them.
Human Verification
