1995 mustang gt
stock
need help once again
I bought this 95 gt last june and have had nothing but problems out of it from the start due to poor maintenance from the prior owner. I can't seem to find a definite problem to my answer this time.
problem 1- I'll start my car in the mornings and back out of the driveway, but as soon as i shift it into drive the engine shuts off. the radio, lights and all the other electronics work, but the engine just cuts off. sometimes it will start right back up, other times it won't. problem 2- If by chance my car actually makes it into drive, it will run fine for a little bit but once i get into stop and go traffic it will start to idle lower and lower till the engine shuts off completely. once again, it might start back up, it might not I've had 6 different mechanics tell me 6 different things ranging from needing a complete new engine and transmission to needing a new distributor. Has anyone here had the same issue that was able to be easily resolved? Replacing parts that may not be broken is way out of my budget. |
Ive been having similar problems. Im beggining to think I got a bad distributer from the part store. When it turns off does it try to start again? Mine will start then die, start and die, start and die, then an hour or few later it will start up and run fine.
1995 mustang gt
stock
yea that sounds about right. i've been told the same thing about the distributor but mechanics have also come up with so many different things like the idle air control, a hole in the exhaust, a bad transmission, throttle positioning switch. just so many different ideas. idk what to think the problem could actually be
1995 Mustang GT 5.0
14.769@93.753MPH
does it throw a check engine light?
95 5.0 poor mans muffler delete Dyno proven Home Depot intake |
1995 mustang gt
stock
nah no check engine light. that's why it's a little confusing to believe that i need a complete new engine.
95 opalfrost gt
most likely culprit is a bad TFI module or PIP sensor
June 2010 ROTM
2000
dont rely just on the check engine light,
use and obdII reader and check for codes. Take it to a Mustang specific shop. Thats all I got.
HPDE Instructor PCA, HOD, Track Guys, ERME www.RaceCarTowHooks.com My Track Videos http://www.youtube.com/user/Msirlin My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
1995 mustang gt
stock
it's a 95 so there is no obdII port. and another problem i have is i'm stationed in north dakota. there really isn't a mustang specific place to take the car.
Mines a 94 but it does have an OBDII port... as should you? Mine just doesnt work if you plug it into it. You have to use the one under the hood. Ive seen a 95 work with an OBDII scanner before but it was a 3.8. But maybe try it?
1995 mustang gt
stock
I didn't realize that. i was under the impression it didn't have one since sct handheld tuners aren't made for them because it did not have one. i'll have to check that out. thanks
95 opalfrost gt
All 94-95 stangs were euiped with the obd11 port as some of the bodys were used with v6s that are obd11. The 5.0 is obd1 and the obd11 port is there just because that is how ford produced the bodies, trust me the obd11 port will net you a big zero. Take my previous suggestion as they are the most likely problem that your dealing with.
Last of the 302's
Road Racing Rookie
Who ever told you you need a new engine should be kicked in the balls immediately, ripoff artist. It's most likely the pip inside the dizzy like mentioned before. Find a shop that deals with Fords or worst case take it to Ford.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
89 GT
I agree. The common trend I've seen on this and other mustang forums when someone has a stall and no hot start condition, generally ends up being the TFI. I believe you can have them tested at a parts store.
You've talked to a lot of bullshit mechanics who only want to make money on you... a hole in the exhaust causing the car to stall and not re-start? An new engine and transmission because the car stalls? come on... some people just need to be punched in the face for being deceitful cocksuckers. |
1995 mustang gt
stock
well the problem is i'm stationed in a very very small town that makes it hard to hide the fact about being military so everyone wants to take advantage. it's ridiculous some of the things mechanics will say. the ford dealership is actually the place that said i needed a new tranny. but thanks. i'll go ahead and replace the distributor and just go ahead and get a full tune-up and see if that takes care of the problem. thanks again
89 GT
The TFI is separate on the SN-95 cars. So if you replace the distributor you won't be replacing the TFI. I don't have one of those cars and I forget offhand where they're located in the engine bay, but they aren't built in to the dizzy, I know that for sure. I would also have it tested before you replace. Just because it's a good likelyhood, doesn't mean that's automatically your problem. The only thing throwing parts at a problem does is lighten your wallet.
1995 mustang gt
stock
yea i was just looking into that. supposedly they used to be installed next to the distributor but after a recall were moved somewhere else, but i'm not exactly sure where. but i figure a tune-up can't hurt anything and when i get that done i'll just have the tfi module looked at
#17 | |
Last of the 302's
Road Racing Rookie
#18 | |
2. Pull out the IAC valve from the throttle body and clean it thoroughly with carb cleaner. I'd be surprised if neither of these simple measures doesn't help in any way but if that happens, have the PIP sensor and TFI module tested before replacing either component. Mechanics will often try to rip you off by recommending radical, expensive solutions to a fairly simple problem so beware.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
