performance parts
Old May 3rd, 2007, 09:26 PM   #1
94gtred is on a distinguished road
performance parts
got 250 to spend what should i get
Old May 3rd, 2007, 09:33 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
a flux capacitor
Old May 4th, 2007, 08:55 AM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.36 @ 105.0
Bullitt95 is on a distinguished road
FRPP 3.73:1 ring and pinion. Best bang per buck mod for any 94-95 5.0 Stang.
244whp/284wtq
Mod list in My Garage
Old May 4th, 2007, 09:00 AM   #4
stang94 is on a distinguished road
Do you have any mods at all?
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old May 4th, 2007, 02:36 PM   #5
Bullitt95's Avatar
13.36 @ 105.0
I'd recommend the 3.73:1 r&p swap even on a bone stock Stang. That said, you could do the following mods for next to nothing:
Remove air silencer
Advance timing to 14 degrees
Remove smog pump assembly
Remove EGR
Remove strut tower brace
Remove rear axle dogbone
Remember that performance is directly related to the power/weight ratio so you can increase it by reducing weight as well as by increasing power.
244whp/284wtq
Old May 5th, 2007, 04:00 PM   #6
Remove air silencer
Remove EGR
Excatly why would you want to remove your strut tower brace?
Old May 6th, 2007, 08:13 AM   #7
Bullitt95's Avatar
13.36 @ 105.0
To save 6lb of weight over the nose. I had to remove mine anyway to install the phenolic spacer between the upper and lower manifolds so I just left it off. That way I won't need to remove it again when I do the H/C/I conversion later on.
Old May 8th, 2007, 06:51 AM   #8
boss302_gt is on a distinguished road
"To save 6lb of weight over the nose. I had to remove mine anyway to install the phenolic spacer between the upper and lower manifolds so I just left it off. That way I won't need to remove it again when I do the H/C/I conversion later on."
The strut tower brace is there for a reason even if you had to remove it for a spacer there are aftermarket braces that will clear your intake. If your simply worried about weight theres also the front brakes, calipers, rotors, sway bar, etc etc etc. Some things are just required for stability.
Old May 8th, 2007, 12:11 PM   #9
lol.. you beat me to it.
that bar helps alot
Old May 8th, 2007, 12:13 PM   #10
95wip is on a distinguished road
Send a message via AIM to 95wip
and unless you have more than 250 to spen i would not dig into my rear end especially if you have alot of miles cause you could end up needing to replace alot of stuf and it can get pretty expensive. i would do the smog pump (air pump) delete if it were me
95' GT is being reconstructed!
Old May 8th, 2007, 05:16 PM   #11
Bullitt95's Avatar
13.36 @ 105.0
Originally Posted by stang94
that bar helps alot
I haven't noticed any difference at all with the strut tower brace removed. I think any difference on a near stock GT is all in the mind.
As for the sway bar, removing that WILL noticeably increase body roll through corners. A tubular K-member and A-arms will save a lot more weight than removing the sway bar, and a pair of aluminium heads will shave a further 40lb off the nose.
When I had my 3.73:1 r&p installed, I also bought a master bearing kit at the same time and had them all replaced inside the rear diff.
I plan to upgrade my tranny as the next mod. I haven't decided which shift kit I'll buy but I'll have the tranny completely overhauled at the same time as the shift kit installation.
Threads Similar to: performance parts
performance parts ExemptTerror SVO 10 August 9th, 2008 04:57 PM
Performance Parts, what to buy gagner15 5.0 Mustangs 6 June 28th, 2007 02:35 PM
