Deleting egr valve on 5.0
LinkBack (2) Thread Tools
Old May 6th, 2007, 07:45 PM   2 links from elsewhere to this Post. Click to view. #1
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
Hey I was wondering I am going to delete the egr valve on my 95 5.0. Now I was looking on ebay and found the simulator, and a delete plate for when you take the egr valve off. also a nut to put on the header. Do you think its worth it? also the only delete plate is for a fow 5.0 will that still work on the 94 and 95 5.0?
heres the links
simulator
http://cgi.ebay.com/ebaymotors/87-95...spagenameZWDVW
header nut
http://cgi.ebay.com/ebaymotors/EGR-H...spagenameZWDVW
delete plate for fox
http://cgi.ebay.com/ebaymotors/EGR-D...spagenameZWDVW
also do you know where I can just buy it all from one place instead of from 3 different people???
Old May 6th, 2007, 11:44 PM   #2
95StangSVT's Avatar
95StangSVT is on a distinguished road
I used the simulator of ebay and the block off plate and i had no problems the only thing is remember to put washers on the bolt that bolts into the back of the cylinder head off the egr pipe ...mine worked fine no problems
Race you for your lady!!!!!!
95 Stang Svt
02 Suzuki GSXR
95 Nissan Hardbody Minitruck (Bagged)
04 Suzuki LTZ400 Quad sport
Old May 7th, 2007, 01:13 PM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
I deleted the EGR valve and also used the eliminator simulator from ebay. I made my own block off plate for the TB elbow, and stuck a coin inside the original female nut and threaded it to the manifold. No issues at all, and I have ample space to change the no.4 spark plug.
Was it worth it? Hell yeah! I'd already removed most of the smog pump assembly so I'll also have ample space to unbolt the old exhaust manifolds and replace them with headers.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old May 7th, 2007, 05:19 PM   #4
lugthug713's Avatar
2002 Roush 360R
hey on another site they are telling me not to b/c it will throw codes for the vacum line. have you had this problem?
Old May 8th, 2007, 04:31 PM   #5
Bullitt95's Avatar
13.546 @ 105.32
No. I plugged the vacuum line so I've had no problems at all.
243.5rwhp/284.2rwtq
Old May 8th, 2007, 07:42 PM   #6
lugthug713's Avatar
2002 Roush 360R
what color was the vacum line do you know the vacum lines and where they go???
if you could click here and then pm me and let me know
thanks
http://www.allfordmustangs.com/forum...cum-lines.html
Old May 9th, 2007, 11:29 AM   #7
Bullitt95's Avatar
13.546 @ 105.32
I can't remember which color was the vacuum line that came off the EGR valve but it goes forwards under the intake manifold and comes out on the passenger side to go through the inner fender. The lines are plastic and they become very brittle with age. All three of mine (pink, red, and green) broke so I capped them all (my smog pump's also gone).
243.5rwhp/284.2rwtq
Old May 10th, 2007, 06:22 PM   #8
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
There is no real reson to delete the egr other than to clean up the engine bay. If you do delete it have that function turned off in the pcm. Using the simulator is a waist, it only gets rid of the check engine light. You will still be prone to detination.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old August 10th, 2007, 10:17 PM   #9
p-351's Avatar
90&94 GTs; 79&91 Broncos
p-351 is on a distinguished road
95opal--
Is there any way to get the EGR function turned off in the PCM without getting a chip burned or something like the TwEECer? I've been chasing pinging problems on the wife's 94GT and ended up deleting the tube (it twisted off when I tried to take it off to look at it). I closed off the the holes, put a screw in the vacuum hose, and set the plunger to where the CEL doesn't come on--the resistor assembly didn't keep the light off for me.
Link to my supermotors.net page: http://www.supermotors.net/users/p-351
Link to my AMSOIL page: http://www.redriversynthetics.net
Old August 11th, 2007, 10:12 AM   #10
Bullitt95's Avatar
13.546 @ 105.32
I used the EGR eliminator simulator that I bought in ebay from c182pilot. Cheap, looks neat, and it works.
243.5rwhp/284.2rwtq
Old August 23rd, 2007, 12:49 PM   #11
Zak
Zak is on a distinguished road
How come? Chances of getting detonation are reduced when the EGR is removed especially in places with a hot climate. Plus of course, getting rid of all that plumb work under the hood.
But it adds nothing to performance because at WOT, the EGR is bypass and the valve is completely closed.
Old August 23rd, 2007, 02:17 PM   #12
95opal's Avatar
95 opalfrost gt
True that on the WOT situation, but at idle and part throttle there is definately going to be more of a chance of detination.
A hot climate is even more reason to keep it as the exhaust gases are used to cool the cumbustion chamber. Hence reducing emissions and detonation. Which as you all know 94-95 cars are prone to due to the fact that our pcm is load based, unlike the fox A9l.
P-351.... The only real way areuond it is to have it turned off in the pcm via a chip, tweecer, PMS or the like. Like I said there is no performance gain from removing the EGR it only helps clean up the enginebay.
BTW.. I do have mine removed but it has also been turned of with my tune.
5.0 magazines
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/21765-deleting-egr-valve-5-0-a.html
Live Mobile Search This thread Refback February 12th, 2012 09:46 AM
Threads Similar to: Deleting egr valve on 5.0
deleting pollution pump BROKINARROW 5.0 Mustangs 3 November 3rd, 2007 05:16 PM
Deleting A/C and smog Tony_90fox 5.0 Mustangs 33 March 24th, 2007 09:21 PM
98 cobra 4.6 4v imrc deleting 98whitecobra 96-98 3 March 23rd, 2007 04:52 PM
Is Someone Deleting My Topics? 00SoSlow The Clubhouse 15 September 16th, 2006 12:17 PM
