94 gt fuel pump relay location? - Forums at Modded Mustangs
post #1 of 17 Old June 2nd, 2011, 09:19 PM Thread Starter
91cobra5.0's Avatar
Anyone know were to find it?
91cobra5.0 is offline
post #2 of 17 Old June 2nd, 2011, 10:19 PM
Inside the Constant Control Relay Module. CCRM
Bubba95SN is offline
post #3 of 17 Old June 2nd, 2011, 11:04 PM Thread Starter
91cobra5.0's Avatar
Can it be unplugged without causing any harm? I used to unplug my 91s fuel pump relay at night to prevent theft and would like to do the same with the 94
post #4 of 17 Old June 3rd, 2011, 01:51 AM
i believe it is in the trunk under the driver side panel towards the back of the car. right next to the taillight. you gotta pull up the panel that blocks it.
and unplugging it shouldnt hurt at all, you gotta unplug it when you do anyhting with your fuel lines. but i would suggest removing the negative battery cable and resetting the computer when you do tho.
h949h is offline
post #5 of 17 Old June 3rd, 2011, 01:58 PM
hotmustang95's Avatar
Originally Posted by h949h View Post
i believe it is in the trunk under the driver side panel towards the back of the car. right next to the taillight. you gotta pull up the panel that blocks it. and unplugging it shouldnt hurt at all, you gotta unplug it when you do anyhting with your fuel lines. but i would suggest removing the negative battery cable and resetting the computer when you do tho.
I think that's the inertia switch your talking about. It shuts the pump off in an accident. You can't get into the CCRM.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
hotmustang95 is offline
post #6 of 17 Old June 3rd, 2011, 06:23 PM Thread Starter
91cobra5.0's Avatar
so just for last night i unplugged the big connector on the coolant overflow bottle and that shut off the fuel pump when i put the key in and turned the ignition to the on position.
but i want to wire in a permanant easier way to make the car non operational unless i want it to ne aka a kill switch
where would ne the easiest spot? i saw the inertia switch in the trunk. can i wire a switch into one of those wires going to the red button and have that kill the fuel pump?
or is there an easier spot?
post #7 of 17 Old June 3rd, 2011, 10:01 PM
your right, my bad.
h949h is offline
post #8 of 17 Old June 4th, 2011, 01:32 AM
any type of swith wired into the circuit will cut power to it. you can put it wherever you want really. i would say under the dash or something so you can get the circuit from the ignition maybe. this is just a spur of the moment idea.
1994 Black GT-Sold
1996 White Cobra S/C-Sold
2001 DHG Bullitt S/C
Click on Logo
ntilehman is offline
post #9 of 17 Old June 4th, 2011, 11:29 PM
95RED5.0's Avatar
Is the car 5 speed or Auto?
95RED5.0 is offline
post #10 of 17 Old June 5th, 2011, 12:12 AM
ryanw's Avatar
ya you should wire in a switch that you can get to from the drivers seat.....you dont want to get under the hood or trunk every time you want to start her up or disable her.....plus you dont want people to see that for some reason you have to lift up the hood/trunk every time , they may put 2 and 2 together
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
post #11 of 17 Old June 5th, 2011, 09:59 PM Thread Starter
91cobra5.0's Avatar
so ive just been unpluging the inertia switch at night and just picked up a winner internation pedal lock, feal pretty safe with that
post #12 of 17 Old June 6th, 2011, 06:24 PM
It's sad that you live somewhere that you have to be that concerned with the security of your car.
1995 SVT Cobra #182/4005, 275/305, 221k miles, Roush Stage III Induction, export taillights
1996 SVT Mystic Cobra #1666/2000, 308/305, 202k miles, export taillights, MM suspension, bolt ons
1995 Mustang, 3.8L, 243k miles
1993 Mustang LX, 2.3L, T5 swap, 03 Cobra steering and brakes, 8.8 w/ 3.73s, 270k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Cobraman1024 is offline
post #13 of 17 Old June 6th, 2011, 06:29 PM
yes you can. I briefly came up with a plan to refurbish them since I found out where I can get the replacement relays and I drew up schematics for the electronics of it. Several different types of CCRMs were used depending on the engine and year of the car. Hell, I even have one on my '93 Mustang LX with the 2.3L engine.
sold: 1987 GT
post #14 of 17 Old June 6th, 2011, 06:52 PM
johnGT's Avatar
What exactly is the CCRM and what is its purpose? I always see that phrase come up but I never really know what it is. Ah, modern electronics in cars..
1995 Mustang GT vert: AODE, 2.73 gears, O/R xpipe flowtech mufflers , 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
johnGT is offline
post #15 of 17 Old June 7th, 2011, 01:35 AM Thread Starter
91cobra5.0's Avatar
tell me about it, i have to look out the window anytime i hear a car i think is similar to mine, its stressful but mustangs get stolen left and right out here
post #16 of 17 Old June 7th, 2011, 05:39 PM
CCRM stands for Constant Control Relay Module. Its a box with a bunch of the most important relays and switching transistors in it. The fuel pump relay, the air conditioning high speed cutoff relay, the low speed fan relay and the high speed fan relay.
Most of the time that you have an electric fan failure in the 1994 and up Mustangs, the low speed fan relay inside the CCRM is at fault. The relay can either stick or just wear out.
On the 94 and 95 Mustangs the CCRM is located on a bracket mounted over the coolant recovery bottle. Its located in the same place for 96-98 3.8L v6 Mustangs. On the 96 and up v8 mustangs, its located inside the passenger fenderwell bolted to the cars frame.
The 93 and prior 2.3L Mustangs also have a CCRM and its located on the passenger strut tower.
Lots of other cars use a version of the CCRM and they all look very much the same; a black box with a wide three row plug with several wires leading to it.
The plug is held to the CCRM by either an 8mm or 10mm bolt going through the center of the plug; very much the same way the main wiring harness is attached to the ECU.
sold: 1987 GT
post #17 of 17 Old June 7th, 2011, 05:42 PM
I do the same thing in my place; in the last year and a half my storage unit was broken into and $1500 in stuff stolen, a brand new k-member from Summit Racing was stolen right off my doorstep within minutes of UPS delivering it and the neighbor kids threw a rock at my car putting a large chip in the paint (paint was two years old and cost $4200) in the body panel over the door window and side of the windshield.
sold: 1987 GT
Human Verification
