Discussing What year 351W Block in the 94-95 Forum. I found a few 351 block, off of some bronco, the thing is most or ...
Old May 12th, 2007, 07:53 AM   #1
I found a few 351 block, off of some bronco, the thing is most or all of them are in 1981-89 block somewhere around there. From what I understand ford only made roller block from 94-98. Am I better off with a roller block, or would one of these work. If I use one of these older 351 Block. What will not transfer from my current 302 over, what else would I need to buy to make it run good. (I know the lower intake wont work. What else.. a list will be nice.
Again should I keep looking for a Roller Block cuz this is a next summer project. I am not looking to get past 600 HP (crank) and I heard the 351 Will do that. Also this will be 90% street car
FREE & FOR SALE
198x 351W Block - 90,xxx Miles (FREE)
94-98 GT Hood, 2 pr tail light - 1 Pr power mirror - FREE
NEW - ENERGY SUSP Motor Mount POLY, RED ($100)
NEW - Reserve Glow Blue/Green ($50)
Old May 12th, 2007, 08:45 AM   #2
Also would I be better off with Carb or EFI? I never have carb but wouldn't mind going for it... if I gotta buy a new lower intake, I might as well? what do you guys think.
FREE & FOR SALE
Old May 17th, 2007, 03:39 PM   #3
95oldyeller's Avatar
well the simple way to go would be to find a 351 roller. like in the lightning,f-250-350's. but the non-roller block's, from what i've heard are a bit stronger. the only down side to the non-roller is that if you want to use a roller cam setup, you'll have to buy a set of those "retro-fit" linked roller lifters that cost almost $500!!! you could use 302 roller lifters but you'd have to drill holes for the spider plate and you'd be limited to small base circle cams.which to me, would be point-less for a performance 351W. but to sum-up the question, i'd go w/ the non-roller block. because even though you have to spend more money up front, you'd have a lit bit of a stronger block, and you'd still have to buy about 95% of that stuff in the long-run to upgrade the original roller block.
Go Tarheel's, your our men, if you can't do it!!!............................................. ...............................DAMN!!??
Threads Similar to: What year 351W Block
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 10:57 PM
351W Marine Block stang94 94-95 13 July 24th, 2007 09:13 AM
351W (1971 2V, 9.5) w/Small Block C6 Devilman For Sale 2 July 10th, 2007 06:21 PM
where can i get a NEW 351w block? nba1341 Classic Mustangs 13 May 8th, 2007 12:55 AM
425 cubic inch (351W stroker) small block Ford and converter Darrell For Sale 0 February 27th, 2007 11:45 AM
