94 gt surging
94 gt. 5 speed. 140k miles. all stock
i got the car last saturday with a slight surge. once i drove it the 80 miles home it started surging even worse. once i shut the car off and tried to restart it. it would start then die immediately. i tested the TPS and it was shot. so i replaced it. it seemed to stop for about a day. then i took the IAC back off and checked it out and it was FILTHY. so i replaced it today. now it still surges every once in a while but not as bad. i have unhooked the battery to reset the computer to let it read that it has a new sensor and all that jazz. and even used a stethoscope to check for vaccuum leaks and cant seem to find any. what should i check next? im completely stumped and it needs fixed because its my DD.
1995 GT
try checking and cleaning the MAF, i had a problem with that a little while ago.
did it fix it?
i cleaned the mass air flow. it seemed to fix it a bit. its not as big of a surge but its still there.
2004 Mustang
![]() iTrader: 1 reviews
i have an issue kind of like this on my 04 what do you look for when cleaning the MAF to see if its damaged
1995 GT
it did fix it for a while for me, but i think mine is a vacum leak.
i would check the line on the back of the intake. it is VERY known for being cracked and leaking.
Threads Similar to: 94 gt surging
| 98 gt surging | slowwwwkid | 96-98 | 1 | March 9th, 2011 12:24 PM |
| car surging | BDaily | 99-04 | 8 | November 13th, 2009 07:00 AM |
| Surging | Mywhite00gt | 99-04 | 7 | October 26th, 2008 05:56 PM |
| Surging BAD | adrenaline=lifeline | 99-04 | 10 | July 20th, 2008 04:46 PM |
| Surging 5.0....Please help | REBELPONY | 5.0 Mustangs | 28 | August 30th, 2007 01:53 PM |
