1994-95 Cobra Intake Manifold Casting #s
Old July 4th, 2011, 11:29 AM   #1
swami is on a distinguished road
Question
hi all,
a friend of mine found a sweet deal on a 1994-95 cobra intake but i need casting #s so i won't taken by a clone of some sort. TIA
Old July 4th, 2011, 12:27 PM   #2
'02 4.3L V6 / '95 GT 5.0L
One Bad Sixxx is on a distinguished road
Send a message via AIM to One Bad Sixxx Send a message via Yahoo to One Bad Sixxx
All lowers are the same, I believe. As far as uppers, they all look identical, and even an untrained eye can tell the difference, you wouldn't need casting numbers.
If it doesn't look like the one in the picture (the one I'm using now), then it's not from a Cobra.
Really, most people look for the upper and lower Cobra and Explorer intakes because those are the suitable substitutes to the true GT-40 upper and lower intakes, most commonly found in the older Lightnings and I believe the 94-98 style Saleen s351.
http://img.photobucket.com/albums/v289/StreetStangs/V6%20Stroked%20Blown/sig1smc-1.jpg
Old July 6th, 2011, 07:57 PM   #3
1995 SVT Cobra
Cobraman1024 is on a distinguished road
That upper intake isn't even a true 94/95 Cobra intake--------as in one that was a factory original. Yours is a Ford Motorsport SVO intake with the "5.0L Cobra" intake plate stuck onto it.
The OEM intake has the "5.0L Cobra" and snake cast into it-------its not an attached plate like the '93 Cobra upper intake.
This is the upper intake from my personal 1995 Cobra...........
and a closeup shot of the face area. Notice the vertical strip between the snake and "Cobra"? Because your face area is just a plate, it does not have this vertical line. My facing is actually cast into the upper intake.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old July 7th, 2011, 07:48 AM   #4
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Wow good info!! I never knew that.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old July 9th, 2011, 01:37 PM   #5
good info. thanks guys!
Threads Similar to: 1994-95 Cobra Intake Manifold Casting #s
Cobra Intake Manifold 95BlackGT5.0! 5.0 Mustangs 8 November 2nd, 2010 12:33 PM
SVT Cobra heads and Intake Manifold CCCustom 96-98 6 June 11th, 2009 07:57 PM
Cobra Intake Manifold Mystery rasalibre 5.0 Mustangs 15 December 14th, 2008 04:06 PM
intake manifold/heads...98 cobra? 98cobra 4V / SVT 16 July 15th, 2008 11:56 AM
