help with 351w swap!!
Old July 8th, 2011, 04:21 AM   #1
94 mustang gt
94mustanggt5.0 is on a distinguished road
im wanting to swap a 351w in for my 302 in my 94 gt. Now with the research i have done still have me questioning which year to get the motor from? solid or roller? efi or carb? i want the most power i can get for the price. i just dont know what to pull the motor from? what should i do for transmission? help and opinions wanted thank you
brandon
Old July 8th, 2011, 12:47 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
How much money are you working with for the swap?
If you are going with an auto, you are almost limited to an EFI setup unless you run an older auto trans like a c4. If you are going manual, you will need a built up t-5 trans at least and you have the carb option.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old July 8th, 2011, 03:55 PM   #3
94 mustang gt
well it just depends on what i need really. i really wanted to go carbed cause i heard it was easier. i cant go with a manual trans cause im paralyzed do to a recent car accident and another question i had was about the computer?
Old July 13th, 2011, 10:18 PM   #4
Timm10221's Avatar
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Timm10221 is on a distinguished road
PA makes a AODE Controller if he goes carbed and you can dial in your shift points with the controller as well. So you can run a Carbed Car with a AODE...
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Old July 19th, 2011, 07:25 AM   #5
2004 Mustang Gt
40thanvblkgt is on a distinguished road
Personally I say go carb'd cause I think it's better than fuel injection unless you feel like pouring money into a standalone efi setup but in your case it may be cheaper to do efi cause you can just chip the factory computer or do a fast ez efi setup they are resonably priced and I'm goin carb'd with my 418w and I'm putting it in a 95 v6 body I'm just gonna chop out the ecu and rerun the necessary eletrics but honestly you would be better off with fuel injection but it's really up to you, you just gotta weigh your options
Old July 19th, 2011, 01:46 PM   #6
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
^ Why would you need stand alone? The ECU in a fox can do it, and it can in a SN95 as well...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old July 19th, 2011, 10:00 PM   #7
2004 Mustang Gt
I never said he needed a standalone I just stated what my opinion was and how I am doin my 351 swap. If I came off that way it was never my intention to do so, I merely just stated my opinions cause I really don't care much for the factory ecu of the 5.0s I just stated my opinion that's all. If your not trying to set the world on fire stay fuel injected get a chip call it good or buy a fast ez efi kit if you want like what I'll be making when my setup is done go carb or drop the cash for a standalone. Just my .02 that is all so you can take it or leave it won't hurt my feelings none, just tryin to help out.
Old July 20th, 2011, 02:55 PM   #8
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
get a motor out of a 95+ f150 250 350 or van they are all roller efi 351 w and can stand up to 900 horse
Old July 20th, 2011, 06:11 PM   #9
2004 Mustang Gt
Roller windsor blocks are only good to 550 or 600 then they break the main webbing, late 70s and later on are about the same maybe a bit stronger but the 69-74 are the strongest but only trust a 69 or 70 block for a real high hp application they have been used for 1000 hp setups without breaking
Old July 21st, 2011, 05:31 PM   #10
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
40th...whoa. Calm down. Just stating.
Anyway. stock ECU with a tune can do it. Granted the 94/95 ECUs sucked even compared to the A9L. Either way. SHouldn't be a problem as long as you don't go super radical on the setup.
Side note. Windsor blocks handle well more than 550-600hp, even the 'weak' ones cast after the late 60s, early 70s. Ive seen 800hp Windsors...hold. Stock crank, good rods and pistons...stock block...with boost. If your goal is 4 digits, get an aftermarket block. If you want to stay around 800 tops. You will be fine if you stuff good parts in it and run a girdle and good safe tune...
96 GT-Cammed E85
www.KPERacing.com
Old July 25th, 2011, 01:15 PM   #11
s351r13's Avatar
1996 Saleen S351
s351r13 is on a distinguished road
94/95 ECU's aren't any better or worse than a A9L. The A9L is just easier to tune.
96 S351 #13
99 S351 #14
99 S351 #46
94 S351 #35
95 S351 #43
00 S281 #417
02 S281SC #117
Old July 28th, 2011, 12:19 PM   #12
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^Ok. Well. That would be in MY OPINION crap compared to the A9L. WHy would I want something thats harder when easier is so readily available.
Moving on...
96 GT-Cammed E85
www.KPERacing.com
Old July 30th, 2011, 10:26 AM   #13
s351r13's Avatar
1996 Saleen S351
Its not actually harder. Tuners early on didn't know how to tune them and never learned. A few functions are different. Its actually more trouble to do the fox computer swap now than to just tune the car the right way.
96 S351 #13
99 S351 #14
99 S351 #46
94 S351 #35
95 S351 #43
00 S281 #417
02 S281SC #117
Threads Similar to: help with 351w swap!!
351w swap? nileppezdel77! 99-04 26 April 3rd, 2011 09:38 PM
351w swap into 00 v6 got poney V6 Mustangs 13 March 15th, 2011 04:58 PM
351w Swap 04ZincGT 99-04 2 March 1st, 2011 10:51 PM
95 V6 to 351w swap help hurricanegamex V6 Mustangs 2 November 19th, 2010 07:28 AM
302 to 351w swap happyjack1992 5.0 Mustangs 2 December 3rd, 2009 11:08 PM
