Cam & Drivability Question
Old July 10th, 2011, 03:45 PM   #1
1995 Mustang GT
95BlackJack is on a distinguished road
Ok so first car info: 95 Mustang GT. 5.0, 5 speed manual
Known mods: BBK Shorties, hollow cats, cherry bomb incinerator cat back, MSD wires, Mild Cam (?)
Bought the car with these mods in it and i'm having some tuning issues.
IS there a cam that someone might use that gives all low and mid range power but loss at high rpm? (above 4,000).
i have a ton of power and pull between about 2,800 rpm and 3,500. Timing is set about 13 degrees advanced. It starts kinda hard, just lugs over a few times before starting up. If i retard the timing, i get misfire above 3,500 rpm real bad and the SES light comes on for a rich condition about 10 times a day. If I Advance the timing more, i get awesome power above 3,500 rpm, all the way to 6K. It will smack me back in the seat and take off, but it will also spark knock like hell that advanced and hardly starts at all when it's hot.
Any ideas here??? I've also noticed car is running hot. Distributor is brand new from auto zone, OEM Spec. Coil looks factory and old. plugs are so-so in it right now.
is it possible my cam to crank timing might be off by like 1 tooth?
Somebody help! I'm tired of trying to fix this and feeling like shooting at the stars instead....
Old July 10th, 2011, 10:46 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I would replace the coil and wires before anything. Your old coil and wires may not provide enough spark at the higher RPM's and may be the cause of the hard starting issue.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old July 11th, 2011, 10:14 AM   #3
1995 Mustang GT
i've been thinking coil now for a little while. the wires are brand new 8.8's, and the plugs look questionable....
Threads Similar to: Cam & Drivability Question
serious drivability issues redrocket 99-04 4 May 17th, 2010 11:51 PM
Drivability prob MATT02GT 99-04 13 June 25th, 2009 01:49 PM
Drivability tune RyanGT 99-04 18 July 4th, 2008 12:39 AM
Drivability 07stanggt 2005 - 2010 43 April 8th, 2008 09:38 PM
nitto DR drivability leebunnyz 2005 - 2010 42 August 10th, 2007 04:49 PM
