94 GT
13.95@100
![]() iTrader: 2 reviews
No crank - shift selector?
When I pulled the motor/trans out of my Mustang I banged up the plastic electronic piece that goes on the shift selector shaft. I'm not sure what it's called, but I found a 96 Mark VIII 4.6 with the same part. I mounted it up and plugged it in but get no crank in any gear position. I moved it around manually and still nothing.
The relays click so it sounds like a loose power wire or ground, but I had another one from a different Lincoln and got the car to crank and run on that. I can't use it though because it mounts up totally differently. It's the little things at the end of a major project that really suck when they mess you up. here is a picture of the part
That's the manual lever position sensor (MLPS) or transmission range sensor. It also acts as a neutral safety switch.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995 SVT Cobra
that was going to be my first guess since yours is an automatic, the neutral safety switch is the faulty component.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
94 GT
13.95@100
Got a new NSS from autozone and a new positive battery terminal. I was able to start it a few times while messing with the timing trying to get it to run well. Now it's doing it again so I'll mess with it more tomorrow.
Threads Similar to: No crank - shift selector?
| a/c selector switch hoses *need any help please* | sj408 | 99-04 | 1 | June 20th, 2011 08:29 PM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
| AOD selector problems | 78mach1 | 5.0 Mustangs | 4 | August 11th, 2008 04:35 PM |
| Tranny cable slipping off of gear selector | OTreborO | 5.0 Mustangs | 0 | May 9th, 2007 01:20 PM |
