Need Help Quick
Old July 15th, 2011, 12:01 PM   #1
jordon's Avatar
1995 Mustang GT
jordon will become famous soon enough
Need Help Quick
Alright, I got in my car and drove to work this morning. No problem. Worked for a couple of hours before taking off for the day...got in the car....turned the key....one click and then nothin. No lights were left on or anything....but whatever. Hooked up jumper cables, light under the hood came on...I thought ok good sign. Turned the key.....one click and then nothin. The light under the hood started pulsing. I readjusted the jumper cables, and the light came back on solid....I tried to start it again and more of the same. WITHOUT jumper cables, if I turn the key forward, nothing happens. No radio or anything. Leads me to believe battery or grounds....right?
Before I go throw a new battery in it, could it be anything else?
Aluminum heads, TF upper/lower, bbk tb
c&l intake w/Pro*M Racing MAF, shorty headers
24# injectors, off-road H, custom catback
H&R springs, 3.73's
short throw.....still slow.
Old July 15th, 2011, 01:20 PM   #2
jordon's Avatar
1995 Mustang GT
Threw a new battery in....fired right up. I've never had a battery just die like that. Its always been dim lights or a really weak turn...Anyway, good to go.
H&R springs, 3.73's
Old July 15th, 2011, 01:26 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
In the future, you can test that by placing the negative jumper cable on a ground in the receiving car rather than on the negative battery terminal. This makes it so the receiving car is using the donor's charge, where in a standard jumper cable setup, the donor car is charging the receiving car's battery, which the receiving car then tries to use to start.
It's a good trick for getting a car jumped in a hurry, as if it's just a dead battery, you can get the receiving car started immediately, then it can charge itself via the alternator as it drives away. Of course, it doesn't work if the battery was dead because the alternator is shot, hahaha.
O o
/¯/______________________
\_\
Threads Similar to: Need Help Quick
Quick! Quick! About to pull the trigger on some 3.73s... Iconoclast107 2005 - 2010 10 November 29th, 2010 12:47 PM
quick quick i need a drinking game for 3 people BostonPerformance The Clubhouse 21 April 22nd, 2010 12:15 PM
Quick question about quick mods for hp Steelsoldi3r 96-98 21 January 23rd, 2010 08:07 PM
Meguiars Quick deatailer.. or Ultimate Quick detailer?? svtkidd23 General Car Care & Detailing 12 January 26th, 2009 12:23 AM
alright quick quick light tint question thorpedo26 The Clubhouse 18 September 1st, 2008 07:36 PM
