What to look out for when buying a 5.0?
Old July 16th, 2011, 04:30 PM   #1
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
boblongtv is on a distinguished road
Send a message via AIM to boblongtv
I posted this in this section because I am currently in the market for another stang. 94-95 to be exact and I am not to familiar with the 5.0 motors or transmission. SO what im getting at is .... should there be things I should stay away from? Is high mileage a problem if im gonna build the motor? Im looking to spend around three grande. Thanks guys
Old July 16th, 2011, 07:07 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
The 5.0 is a GREAT motor. I have over 350,000 miles on my stock motor. Main things to look out for are:
Harmonic balancer- throws the engine balance out of whack at idle and causes the front main seal to leak.
Rear main seal- leaks oil excessively if left untreated.
oil pan gasket- same as the rear main seal. mine minorley leaks, not as big as a deal, you have to lift the motor to replace it though..
Fuel pump/filter- Been through two of each since 1996. Not a big deal, but it does happen.
Head gaskets- look for white smoke out the exhaust and water in the oil!! Costly if you have it done. I have a tiny bit of white smoke in my exhaust every now and then and can smell a hint of coolant when I get on it hard sometimes..but there is no water in my oil and my coolant level stays very consistent so I'm thinking it's solid.
As for the transmissions, my AODE was rebuilt around 230,000~ miles. Started to slip after we moved up into the north GA mountains...just something to think about if you live in a hilly area.
I don't know as much about the t-5, I just know its not good for high HP applications. Only good to around 300hp..
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old July 16th, 2011, 08:00 PM   #3
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
ok thanks. I do plan on getting a stick. So I should remember to beef up the stock t-5.
Old July 16th, 2011, 08:13 PM   #4
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
stock t-5's are good for over 400 hp, just buy a good shifter.
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old July 16th, 2011, 11:16 PM   #5
1995 SVT Cobra
Cobraman1024 is on a distinguished road
I rebuilt my factory T5 at about 165,000 miles. First pass at the dragstrip on New Years day this year I sheared the teeth off 3rd gear. That was at 215,000 or so miles and with about 330hp/360lb/ft tq at the engine. I replaced it with a used ProMotion-built T5 with 60,000 or so miles on it.
Basic stuff about the 94+ up Mustangs:
1. Fuel filler neck gasket will cause fuel to slosh out of the tank when the gasket has deteriorated.
2. some minor issues with the combination switch and the headlight switch plug itself.
3. Odometer gears will eventually fail causing your odomoter to not work. Two gears need to be replaced in the instrument cluster, they generally sell for $20-$25 each.
4. the sensor inside the distributor fails causing the symptoms of a bad fuel pump except you'll find that the fuel pump still builds the proper amount of pressure to the rails.
5. The CCRM or constant control relay module has a very good shot at being the faulty component causing either the low speed, high speed or both speeds of the electric fan to fail.
6. If the car has sat without running for an extended length of time, turn the ignition switch to build pressure in the fuel rails and then start sniffing around the fuel line to rail connections and the flexible portions of the fuel lines in the engine bay. These will sometimes dry out and cause a fuel leak. Not too common but it does happen. Check out the sticky in the 94/95 section of the Corral.net forums for the fuel leak information.
7. caliper slide pins in the rear caliper brackets tend to get frozen in the caliper bracket if they are not properly lubricated on a regular basis. I check mine around every 6 months or so.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old July 17th, 2011, 10:44 AM   #6
johnGT's Avatar
+1 about the odometer gears. Mine stopped turning at about 196,000~. It still runs like it has that many miles on it so I haven't bothered replacing it.
Besides, that was nearly 5 years ago and it would still be off by A LOT. Me and my dad have calculated it multiple times and we know for a FACT that it has at least 320,000. I drive it everywhere though and don't account for many of the random trip miles. It may be closer to 400,000
Old July 17th, 2011, 01:07 PM   #7
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
Ok thanks for the information. Ill let yall know when I find one on craigslist and seal the deal.
Old July 20th, 2011, 02:59 PM   #8
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
keep a close eye on the strut towers mine rotted out and only has like 185k on it in the process right now of fixing that and trust me it sucks lol
Old July 24th, 2011, 11:20 PM   #9
91sleeper's Avatar
1991 notch
91sleeper will become famous soon enough91sleeper will become famous soon enough
look at the tq boxes as well and make sure there not ripped.
It can't be that fast cause it still has the stock hood.
-some punk
Originally Posted by flyin ryan View Post
8 sec 1/4 times are soo 2009. Im running 6 sec slips in my dd 302 pig with street tires
Originally Posted by flattusmaximus78 View Post
Nah not even stock form. I just made it up.
Old July 25th, 2011, 11:12 AM   #10
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
If only they were that strong. Most V8 versions of the T5 are rated at 300-310lbft which is only slightly more than stock, so they definitely need beefing up for any serious performance applications.
Agree about upgrading the shifter though and the MGW seems to be an excellent choice.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old July 25th, 2011, 12:43 PM   #11
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
Agreed, however, we can't just slap a "HP" or "Torque" capacity on a transmission. It's all about how you use it. I had a S trim supercharged 95 GT making 425 to the tires and my T5 held up fine. I beat the snot out of the car on the street, on street tires. I had zero intention on ever running the car on the strip so the T5 was just fine for me.
A TKO or T56 should absolutely be in the cards if you plan to drag race period.
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Old July 25th, 2011, 01:51 PM   #12
91sleeper's Avatar
1991 notch
the clutch and shifter as well as the tires determines the life of a t-5
-some punk
Threads Similar to: What to look out for when buying a 5.0?
So you're looking at buying a car? Enzo_Guy The Clubhouse 126 April 27th, 2011 12:39 AM
might be buying this...... G.T. Rags The Clubhouse 21 February 22nd, 2009 02:16 PM
buying a treadmill is like buying bottled water obdnanr The Clubhouse 18 August 3rd, 2008 10:55 AM
buying a treadmill is like buying bottled water obdnanr The Clubhouse 9 August 2nd, 2008 12:47 AM
is buying a used cam a no no?? 93hatch The Clubhouse 0 June 24th, 2008 07:14 PM
