1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
4Cyl T-5 Vs. 8Cyl T-5
Whats the Diff I had always thought the B.W T-5 for the 4 Cyl, V6 and V8 cars were all pretty much the same. If not whats the Diff?
And on another note will the T-5 from say a 99-04 V6 Mustang Bolt to a 94 GT Bellhousing i figured it should being its the same Trans Splines etc i just think its a e speedo and not a cable 99+ But i cold be wrong...
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
1999 Mustang
Ok, the 4 cyl T5s are notably weaker than the V8 T5s. I think they are in the low 200's as far as torque ratings.
In a pinch, I've used 4 cyl T5's behind the 5.0 in my old 1990 GT and never had an issue. It shifted like butter and I beat the crap out of it and it never missed a beat. Over 2 years of abuse without issues. Keep in mind, if you use a 4 cyl T5, it is the same length as any Fox T5 and will require use of a Fox bellhousing and clutch fork to use it on your 94/95 car. The 99-04 V6 T5s are internally the same as 94/95's with the same exact gear set and torque rating of 300 ft lbs. The difference in these trannies lies in the tailshaft and tailshaft housing. They were designed for the newer magnetic pickup driver for the speedometer where ours still used a mechanical gear and drive gear. If you swap the tailshaft housing over to the 99-04 V6 transmission it will be virtually identical.
![]() 1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq. |
Threads Similar to: 4Cyl T-5 Vs. 8Cyl T-5
| 4cyl to 8cyl conversion wiring harness questions | sharkbait | 5.0 Mustangs | 0 | June 1st, 2010 01:38 AM |
| 4cyl to 5.0 | mustangsoldier | 5.0 Mustangs | 16 | November 3rd, 2008 06:47 PM |
| Difference Between 8cyl and 4cyl T-5 | 88stangGT | 5.0 Mustangs | 12 | April 13th, 2008 02:18 PM |
| 2005 Ford Mustang ( 6cyl. and 8cyl.) TSB's! | Casper98GT | 2005 - 2010 | 26 | February 17th, 2008 08:20 PM |
| conversion problems 4cyl 2 8cyl h.o efi | mustang mikey | 5.0 Mustangs | 1 | February 13th, 2007 08:16 PM |
