AODE trans blown!
LinkBack (1) Thread Tools
Old July 26th, 2011, 10:47 PM   1 links from elsewhere to this Post. Click to view. #1
94 mustang gt
94mustanggt5.0 is on a distinguished road
Exclamation
AODE trans blown!
today i was driving through town in second gear and when it was supposed to shift to third it neutraled out and never shifted. i took the aode to the trans shop and i was told it was internal damage and the tranny oil was really dark and the estimate was $1700 to have it rebuilt so i said the hell with that and i want to know what transmissions will bolt up to my 94 5.o. i know an aode will but idk what years of aode and if there are any other auto trans that will. i never help as soon as possible cause i cant stand riding to work with the girlfriend lol
Old July 27th, 2011, 10:12 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
A '94-'95 AODE from another Mustang, 2WD 5.0 Explorer, or 2WD 5.0 F150 will go straight in. Alternatively, you could modify a 4R70W from a '99-'04 V6 Mustang to make it work.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old July 27th, 2011, 06:05 PM   #3
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
Always a good opportunity for a 5 speed swap as well! I've gotten it done for around 500 bucks before. I have a thread on stangnet with a complete swap if you wanna see what's involved.
Otherwise get a 4R70W or go home! AODE's are slush boxes and really have no business in a performance car.
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Old July 28th, 2011, 04:39 AM   #4
94 mustang gt
what would you have to do to modify the 4R70W?
Old July 28th, 2011, 09:55 AM   #5
99FiveOh's Avatar
1999 Mustang
If you do a google search there is tons of info for hours of reading. I just did a search and there is a Stangnet thread that explains everything you have to swap.
Also, the "guru" I'm finding on this subject is Don at SCT X3 LiveWire Dyno Performance Chips LaSota Racing Ford Tuning Index
Give him a shout!
Old July 28th, 2011, 01:19 PM   #6
Bullitt95's Avatar
13.546 @ 105.32
Not a lot but Don Lasota will know the full skinny. IIRC you'll need to keep your existing '94-'95 wiring harness, shift solenoids, tailhousing, and add extra clutches to the 3.8 V6 4R70W to give it the same holding power as a 4.6 V8 version. The reason you need the 3.8 V6 tranny is that the bellhousing bolt pattern matches the 5.0. The tranny from a 4.6 won't work.
243.5rwhp/284.2rwtq
Old July 31st, 2011, 10:07 PM   #7
acfortier is on a distinguished road
Yes, the AODE tail housing will need to swap over to use the yoke you have.
Yes, you need the RF-F2 ford part number 92-95 TCC (torque converter clutch solenoid)
You can rewire, but the simple solution is to buy a new SS (shift solenoid pack) for the 92-95, and use that in your 98+ trans. Use your 94 internal wire harness and swap it over. The TCC mentioned above only accepts WIRE harness, your 98+ 4R has a PCB style harness and will not clip into the 92-95 TCC.
Also your EPC solenoid (electronic pressure solenoid) will need to be swapped as well from your 94 (or get new) into the 98+ trans to use your old harness.
That is way easier than fighting the re wire proccess.
So in short, take out the EPC, TCC, SS from your 98+ trans, swap in 92-95 RF-F2 ford parts number solenoids, use your old 94 internal wire harness, done. This leaves you with a new trans, with old style solenoids, done.
We can work this scenario around many ways.
There is like 5 ways to do this swap. Another simple way is using a 92-95 TCC, CUT THE SHROUD off the connector so the 98+ PCB internal wire harness will connect to it, then rewire the car connector.
I attached the rewire diagram.
Thank you,
Dan Gilsdorf
Silverfox Performance Transmission LLC
816-365-6215
www.SilverFoxTrans.com
This is exactly what I did, and it worked perfectly. Just make sure you have the right speedo gear
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/227433-aode-trans-blown.html
Thread how to trick the AODE Trans into working with Carb V8 | Mustang Forums | AllFordMustangs.com | BoardReader This thread Refback September 20th, 2011 04:10 PM
Threads Similar to: AODE trans blown!
95 ford mustang 5.0 trans swap aode to standard zxmark14 94-95 2 February 19th, 2011 06:26 PM
Blown head gasket? PVC blown off Stangin94GT 5.0 Mustangs 6 July 21st, 2010 10:15 AM
will a 351 mate to an aode trans? mutlyi4 5.0 Mustangs 1 April 13th, 2010 02:35 PM
AODE to C4 r7r5 94-95 4 June 25th, 2007 09:37 PM
