Hanging Idle when clutch in
Old July 29th, 2011, 06:02 AM   #1
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
Hello everyone!
Long time no post, guess I haven't had any questions latley I could not figure out!
To the problem. Last time I checked in my IAC went out. I bought a new one and replaced it. Now it seems that my idle shoots up when clutch is pressed in. It will shoot up like 1k rpms hanging for a second then drop down kind slow then it will reach i think its under like 2k and drop down to normal. I asked a mech dude I go to and he said check my MAF, The other sensor thats connected to the intake, vacum leaks, and maybe the gasket on the IAC is messed up. Any thoughts suggestions? Also how would I go about checking for a vacum leak?
Also sometimes when above 3k and letting the engine come down on compression (engine braking) the engine will stick at like 2300 rpms. Any and all thoughts appreciated!
Old July 29th, 2011, 12:55 PM   #2
Trick Tuners's Avatar
KB'd GT
If you have a hanging or high idle - Trick Tuners Forums
Old August 1st, 2011, 01:49 PM   #3
BiggusJimbus is on a distinguished road
Thanks. This gives me some guidelines for the same problem. I suspect I know where my problem is.
Threads Similar to: Hanging Idle when clutch in
Hanging Idle? ViperPilot24 V6 Mustangs 14 February 17th, 2011 02:52 AM
help hanging idle rider4life350 99-04 16 November 14th, 2010 11:07 AM
Hanging Idle 90Stang 2005 - 2010 2 November 25th, 2008 11:59 PM
Aftermarket TB/Plenum hanging idle/low idle issues! Novanutcase 99-04 12 August 13th, 2008 11:24 AM
hanging idle Baneful 99-04 11 June 27th, 2007 03:41 PM
