1995 Mustang GT Lurching and slight miss
LinkBack (1) Thread Tools
Old July 29th, 2011, 07:52 PM   1 links from elsewhere to this Post. Click to view. #1
MP Fizzle is on a distinguished road
It's a manual. Lurching/bucking in 1st/2nd gear (I'd like to say that it isn't a driver error). Has a slight miss at idle and through the RPM chain. I'm not sure what has been modified on the car (bought it about a month ago), but I'll try to answer what questions you have to the best of my ability. It was having more problems before, and I pretty much started throwing parts at it.
Here's what I've replaced so far:
IAC
TPS
MAF Sensor
Plugs & Wires
Cap & Rotor
Fuel Filter
Air Filter
U-Joints
Old August 3rd, 2011, 11:19 AM   #2
wizwrath is on a distinguished road
Is there any codes? You may need to do a vacuum leak test. You missed the O2 sensors and the water temp sender (the one on the heater rail, it controls the computer). Did you check fuel presure and the fuel regulator? It also could be your ECU or the PIP pick up in the distributor.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/227803-1995-mustang-gt-lurching-slight-miss.html
Thread 1995 mustang gt constant control relay module | Mustang Forums | AllFordMustangs.com | BoardReader This thread Refback August 4th, 2011 03:11 PM
Threads Similar to: 1995 Mustang GT Lurching and slight miss
Help....Jerking/Lurching at cruising speeds. jdos1 99-04 34 March 30th, 2011 11:06 AM
Will 2006 Mustang GT Wheels fit my 1995 Mustang GT? 95GTConv 5.0 Mustangs 2 April 21st, 2010 10:55 AM
mustang 5.0 slight knocking 88notchback 5.0 Mustangs 0 November 18th, 2009 12:54 AM
slight miss or bad sensor? John's_stang 99-04 6 May 11th, 2009 11:49 AM
Slight Miss When In High Gear / Low Rpm built54 Modular Mustangs 10 October 15th, 2006 11:22 PM
