89 5.0 engine in a 94 GT
Old August 1st, 2011, 03:04 AM   #1
snowwhiteGT's Avatar
snowwhiteGT is on a distinguished road
Question
Hey. I'm sorta new to this so cut me some slack . I just got a built engine out of an 89 GT and I want to swap it in my 94 GT. I got everything from the intake to the oil pan. Will everything just be plug and play or will I have problems with connectors on sensors and things like that? If so, any idea on where to get them and how to convert it over?
Thanks
ONLY REAL DRIVERS SURVIVE www.nosnation.com
Old August 1st, 2011, 12:36 PM   #2
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
Everything will bolt rite in if you use the 89's long block= engine and heads. You'd have to use the 94's front accessories on the new engine so all the plugs and connections line up correctly. Does the new engine come with a better TB and intake? If so use them but you'd need to modify a few little things. We need to know what exactly the new engine has cause it'll determine how you go from here.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old August 1st, 2011, 06:53 PM   #3
87coupe331's Avatar
1987 Mustang LX Coupe
87coupe331 is on a distinguished road
I just put a 90 GT motor in a 94 GT and I can not get any power out of it, and it is all stock for the wife. This thing will not even get out of it's own way. NEED HELP !!! Please
Old August 3rd, 2011, 04:43 AM   #4
it has a trickflow intake and a professional products 70mm tb. It seems like the tps and the throttle spring are in different locations. i think the tps is on top and throttle spring is on bottom. it also has a trickflow stage 1 cam and supposedly some headwork including 2.02/1.60 valves. is this a good combonation???
Old August 8th, 2011, 06:56 AM   #5
Help me!!!
Old August 9th, 2011, 02:56 AM   #6
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
You'll need SN95 accessories and an elbow for the intake.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old August 11th, 2011, 12:24 PM   #7
What do you mean by accessories?
Threads Similar to: 89 5.0 engine in a 94 GT
2005 V6 engine swap to 2002 saleen engine MCLARK V6 Mustangs 7 May 14th, 2010 06:02 PM
2005 V6 engine swap to 2002 saleen engine help? MCLARK 2005 - 2010 7 January 11th, 2010 09:27 AM
Engine install: Life engine up, or drop engine? trill gear head 2005 - 2010 14 October 26th, 2009 01:17 AM
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 10:14 PM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 05:09 PM
